50 hour service...what size is that strainer head?
   / 50 hour service...what size is that strainer head? #1
Lockport
Platinum Member
Lockport, Manitoba
Bobcat CT235
I was doing my 50 hour service (surprised the shroud came off without removing the grill guard) and got it all done with very limited spillage. [/forums/images/graemlins/grin.gif did a genset and car just before so well warmed up]. Anyway, besides the fact I bought the Japanese filters for my Kubota Genset, $99 for a half dozen, earlier in the day and then off to the dealer where he begins explaining about how on the tractor the black oil filters are from Japan, but he has these white ones that are made in North America and they are only $5.99. Great deal. Meanwhile. back at the ranch as I removed the factory filter, surprise, surprise, I discover they are the same as those on my genset! Besides a new alternative for the genset at 1/4 the price, a closer look, however, does reveals what appears to be a quality in the blacks in unison with what one would find in a synthetic filter. I would be curious to cut each open.
So here's my question. I got everything done except refill with SUDT (dealer had the pails! 22 liters) when I realized I do not have a socket large enough for the filter screen bolt head. That is it, isn't it, gentlemen? That huge bolt head just rear and beneath the axle? Anyone know what size it is? I took a brief pull with a vice grip but dug into it and it didn't even move. /forums/images/graemlins/confused.gif /forums/images/graemlins/confused.gif
By the way, oil filter vice grips are the trick for those factory tightened filters. /forums/images/graemlins/grin.gif
   / 50 hour service...what size is that strainer head? #2
i think its one inch or one and 3 -16ths
Thanks. I'll have to call the dealer and get its specifics as it seems I will need to purchase a larger socket.
   / 50 hour service...what size is that strainer head? #4
take a crescent wrench , put it on the nut and adjust till tight, measure between flats and thats the size socket you need.
I don't even have a crescent wrench that large. Closest thing I have is a pipe wrench and I wouldn't trust that measurement.
   / 50 hour service...what size is that strainer head? #6
a pipe wrench and vice grips. guess we know what to get you for xmas.........
   / 50 hour service...what size is that strainer head? #7
Back a while ago someone gave the size of the strainer bolt head in MM.. Not sure that the subject was. I read it myself and wanted to remember it... Now I've forgotten, whats new.
It's a 27mm /forums/images/graemlins/grin.gif /forums/images/graemlins/grin.gif
   / 50 hour service...what size is that strainer head? #10
</font><font color="blue" class="small">( Back a while ago someone gave the size of the strainer bolt head in MM.. )</font>
That was me.
<font color="red"> It's 26MM </font>
   / 50 hour service...what size is that strainer head? #11
<font color="blue">1* (surprised the shroud came off without removing the grill guard)
3*By the way, oil filter vice grips are the trick for those factory tightened filters.
5* It's a 27mm
BX2230_Lockport
~~~~~~~~~~~~~~~ </font>
1*Why take the shroud off? I never do!
3* There isn't enough room for the handles so how do you remove the engine oil filter with them?
I've found the best tool for that is the filter wrench that has 3 claws or fingers.
5* 27 mm may fit over the head but<font color="red"> 26 MM is the correct size.
</font>
1*Why take the shroud off? I never do!)</font>
Is there room? I didn't think there would be room. I just went by the manual anyway.
I've found the best tool for that is the filter wrench that has 3 claws or fingers.)</font>
I got it in there. 'Course I had the shroud off. There was just enough room to turn it about an inch befor hitting the hydraulic lines when approaching from the bottom. You could probably do it with the shroud on, just hard to see.
5* 27 mm may fit over the head but<font color="red"> 26 MM is the correct size. </font>)</font>
Is it 26MM? 27MM worked just fine, course I had
"bit" it with vice grips that may have helped. /forums/images/graemlins/cool.gif
   / 50 hour service...what size is that strainer head? #13
According to my BX manual you don't have to clean the strainer screen at 50 hrs.. Not until 300 hrs. /forums/images/graemlins/smile.gif
   / 50 hour service...what size is that strainer head? #14
You should really clean the strainer more often than 300hrs. The most metal/particles that wear free in the tractor are during the first 25-30 hours of use.
I like the shell rotella with soot protection for my motor.
BTW, its perfectly acceptable to just change the filter and clean the screen occasionally on the trans axle. Given the cost of Super UDT it's an alternative...
-Dave
   / 50 hour service...what size is that strainer head? #15
I have 560 hours on my bx and have done all the oil changes at factory specified intervals and I have never had my shroud off. Here is the wrench that I use. And yes, It is a 26 MM head on the strainer bolt. Wrench
2018 ROSCO LEEBOY CHALLENGER 7 SWEEPER (A60429)
2018 ROSCO LEEBOY...
SEMI AUTOMATIC QUICK-CHANGER FOR MINI EXCAVATOR (A58214)
SEMI AUTOMATIC...
excavator trenching bucket- one bucket per lot (A56438)
excavator...
HYDREMA 912HM ARTICULATING WATER TRUCK (A60429)
HYDREMA 912HM...
2013 Ford Edge Limited AWD SUV (A59231)
2013 Ford Edge...
2016 Kubota SVL75-2 (A53317)
2016 Kubota...
