50 hr maintenance
   / 50 hr maintenance #11
The $276 that I spent on our MF Service manual was worth every penny. Nothing beats the details that the factory manuals give.
   / 50 hr maintenance #12
AGCO has them locked down pretty tight, and they don't give them away $$$$$.
Your fifty hour service should be pretty straightforward, the information should be in your owners manual which you should have received with your tractor. On my 1734e it was filters and fluids. The only complication I encountered was the necessity to remove the loader support subframe member to remove the hydraulic suction filter.
Oh it was also fun putting ten gallons of hydraulic oil in through a 1" hole behind the seat :laughing:
Mapper: on the 1734e there is a 4WD shift lever mechanism right in front of the spin-on hydraulic oil filter. The lever attaches to a shaft that goes into the trans, and has a linkage rod that goes up to the driver's area. Is there enough room to remove this spin-on filter with that 4WD lever so close to the filter?
   / 50 hr maintenance #13
This thread is old, so your chances of getting a response from a 1734 owner would be a lot better if you start a new one.
METRIC DUAL CUT TAP & DIE SET (A58374)
METRIC DUAL CUT...
2001 INTERNATIONAL 4900 (A58214)
2001 INTERNATIONAL...
LOT: (2) 2-Wheel Dollies, Roller Stand, (3) Screw Levelers (A59076)
LOT: (2) 2-Wheel...
2022 Coras Predator Steel End Dump Trailer (A56435)
2022 Coras...
2008 DOOSAN G25 GENERATOR (A58214)
2008 DOOSAN G25...
2018 HINO 338 KNUCKLE BOOM TRUCK (A51406)
2018 HINO 338...
