50 hr oil chainge
   / 50 hr oil chainge #11
Yeah, I've seen the AW sixty-sumthing here at Napa. I was wondering if that would be close? I have AW-32 in the power steering now and interesting that Greg has swithced to heavier to reduce/eliminate the problem I'm having. I think I'll give that a try.
Thanks,
   / 50 hr oil chainge #12
There is also an aw46 available as an intermediate step. I know our local tsc carries all 3..
I'd guess utf would fall somewhere around aw32 .. etc.. perhaps upwards towards 46.. depending on the manufacturer.. etc.
Soundguy
   / 50 hr oil chainge #13
Paddy said:
Greg,
When you did your flush with diesel fuel, did you run the lift?
Absolutely. If you don't all you're flushing is the sump. Exercising the hydraulics circulates the kero to flush from critical pump/valve/divertor areas. Don't forget to clean/replace the suction screen either.
//greg//
   / 50 hr oil chainge #14
DwayneB said:
Greg said ISO 100 is approx 30/40 wt. The ISO 46 is approx 20 wt. I've seen I think ISO 68? here locally.
The place where I work has it in bulk. I just pumped a gallon out of the hose. So I didn't go back to look what was on the barrel. The guys in the shop just said this is 30 wt hydro here.
If you look at the Viscosity Charts you'll see AW46/ISO46 ranked parallel with the low end of 20W - and AW68/ISO68 on the high end. That's why I recommended at least ISO100, which will give you a 30W equivalent or better through the steering pump.
It's still not thick enough for me on a hot summer day, but there's nothing thicker available around here in quart quantities. I'm using 50W racing oil from AutoZone in summer, and may go to the ISO100 in the winter if the 50W proves too thick. After all, we're only talking a quart and a half oil change here.
//greg//
   / 50 hr oil chainge
OK greg.
I should unhook the FEL lines so I don't end up with a gal of diesel in the system when exercizing?
   / 50 hr oil chainge #16
Well, it's Chinese fluids and their residue we're purging here. If it's not a Chinese loader - and hasn't had Chinese fluids run through it - flushing that circuit is optional I guess.
The specific gravity of AW32 (~.860) is awfully close to that of typical diesel fuel (sg~.865). That's why I recommend kerosene (sg~.817) instead; the lighter specific gravity makes it separate better in the sump. And being more volatile, what little kero doesn't drain will evaporate faster than would diesel. So if you do decide to flush the FEL circuit, residual kero shouldn't be an issue.
//greg//
NEW Slip On Fork Extensions (A53002)
NEW Slip On Fork...
1992 Effer 7600 2S Knuckleboom (A51691)
1992 Effer 7600 2S...
2008 KZ Sportsman Police Bunk 5th Wheel Tri-Axle Travel Trailer (A51694)
2008 KZ Sportsman...
2018 Club Car Carryall 1700 (A51573)
2018 Club Car...
2022 John Deere HD50F Draper Head (A53342)
2022 John Deere...
LOOK! (A53342)
LOOK! (A53342)
