5045E Wiring/Diagnostic Guide
   / 5045E Wiring/Diagnostic Guide
I don't know. I am heading out to the farm to run continuity tests on it. I'll check ground as well.
The relay tests out good and ground is good. Since I am getting voltage to the big post and the relay is not working, I am not getting voltage to the small wires to activate it. The wiring diagram in the manual is poor so I need to visually check where the small wires go.
   / 5045E Wiring/Diagnostic Guide #13
I'm assuming by "big post" you are referring to the contact on the relay/contactor. I'm also assuming by "small wires" you are referring to the coil for the relay/contactor? Depending on how complex the electronics are on your unit will determine how complex that "small wire" or starting circuit is. That circuit will be initiated by the key switch.
Correct. The small wires go into a Deutch connector and then into the relay. If I disconnect the Deutch connector and put the ignition in run, I get 11 volts into that small wire. When I plug the connector back in, I don't' get voltage and the relay makes noise.
   / 5045E Wiring/Diagnostic Guide #15
Sounds like you have a loose connection somewhere that is causing the coil to drag the voltage down. Or maybe a ground in the circuit. Have you checked for grounds. That's the first thing you should have done.
I did. I'm pretty sure the starter is bad. Maybe it is causing it.
   / 5045E Wiring/Diagnostic Guide #17
Disconnect the starter and see if the relay works as it should.
That's my next step when I get to the farm.
When the starter is disconnected I get voltage to the S (small wire on the starter solenoid). The odd thing is I get that voltage in the start and run positions. I thought you only want it in the start position.
   / 5045E Wiring/Diagnostic Guide #20
It's easy to supply power to small S solenoid terminal by jumping it to large terminal which goes to battery +. If it engages and cranks then solenoid and starter are OK. If not then replace it.
2014 DRAGON 130 BBL STEEL VACUUM TRAILER (A55745)
2014 DRAGON 130...
PEMBERTON LR129-1123 RAKE ATTACHMENT (A56129)
PEMBERTON...
2019 MDB FM180 FINISHING MOWER (A51247)
2019 MDB FM180...
JOHN DEERE 5075E LOT NUMBER 30 (A53084)
JOHN DEERE 5075E...
2017 E-Z Beever M12R Towable Brush Chipper (A50322)
2017 E-Z Beever...
