Price Check 5083e and 5085m pricing?
   / 5083e and 5085m pricing? #1
pheasantboy
Narrowed down to the 5083e and 5085m. First the M -3 rear and mid svc's a, air ride seat, FEL w skid steer setup and bucket and deluxe open station. E series (cab of course), air ride seat, 3 rear and 3 mid svc's (3rd one is dealer add on) FEL w skid steer and bucket
Quoted low 52k for each
oh yea -2012 models
are they in the ballpark of what y'all seeing
   / 5083e and 5085m pricing? #2
The 5083E should be a lot less expensive. With a loader it should be low to mid 40's before taxes out the door. The 5085M with the cab should be at least 10K higher. It has more options and is a bigger beefier tractor. That said, the 5083 is no slouch and may do what you want just fine.
   / 5083e and 5085m pricing? #3
The 5085M is alot more tractor in every way, to get an idea of what these tractors should cost I recommend you price them on the JD configurator and get the msrp price. Then deduct about 15 to 18% that should put you in the ballpark. Putting a number to a tractor depends on what option it has and this can make a huge difference in the final selling price.
Have you compared the 5083E to a 5085M side by side? These are really two different tractors with the 5085M being the heavy duty model.
   / 5083e and 5085m pricing? #4
I ended up around 16% below MSRP on my 5075M. That wasn't the lowest quote I got, though... but the lower dealer didn't make me feel confident that he'd be able to come through the deal without some "last minute" hangups or problems that would end up costing me more money, anyways.
So, I went with the next lowest bid and a better "peace of mind"! :D
As other's have stated - try to look the tractors over on the dealer's lot if possible. Considerable difference between machines.
That may or may not be an issue -- alot depends upon how you plan to use the tractor and what future purposes you might have in mind.
AKfish
   / 5083e and 5085m pricing? #5
I bought mine a year and a half ago with the 563 loader and global quick attach for 41,800. That also included the heavy duty bucket with bolt on cutting edge and forks. Great tractor, but if I could do it all over again I would go with the M series for the heavier frame, hydraulic capacity, better tires and all the goodies in the cab. Absolutely no regrets on going Deere though.
Thanks Gentleman
going with the M series
I will let you know where I end up (ie % discount from MSRP)
it will be the 2012 model series!!
6 yrs in the waiting
   / 5083e and 5085m pricing? #7
Thanks Gentleman
Congratulations! Looking forward to seeing the "fruits" of your waiting!! :thumbsup:
AKfish
   / 5083e and 5085m pricing? #8
Pheasantboy,
I would see if you could sneak a cab onto the 5085M as well. Can't go wrong with a cab even with the extra couple bucks up front.
   / 5083e and 5085m pricing? #9
I was in the same position as you about 9 months ago. I was struggling with the price difference between the E series vs M series. I had to search for a while until I found a dealer that had both tractors sitting side by side. HUGE DIFFERENCE! You will find the M series is a lot more beefier tractor. I ended up buying a loaded 5105m (deluxe cab, 32/16, 2 front/3 rear remotes, w/ 563 loader) for less than $62,000 (delivered in August 2011). You should be able to get a loaded 5085M with deluxe cab and loader in the mid $50's. I have no regrets for spending the extra money for the M.
If I could give you one piece of advice it would be to get both tractors side by side, study them closely and then drive them. That's what sold me.
   / 5083e and 5085m pricing? #10
Just spent some time at Deere and saw the 2012 5083e tractor. What a change from 2010. Biggest difference is the cab. Has the side console like the M-series, but with just a few less dodads. The whole tractor is green instead of the ugly black frame like before. Rear remotes are just like the M with metal lines instead of the rubber. Only part I don't like is the anti-sway uses chains instead of the bars with pins and the lift eyes are cat II only. Total out the door is 47k and I couldn't help myself and traded in the 2010. Comes with the new style loader instead of the 563. In that price is an air ride seat and third function valve.
I would love a cab on the tractor! -I think it just puts me over the top on what I am comfortable spending -- (kid n colleges). Good or bad -I dont need to spend all day on a tractor, but boy it made me rework my budget to see if i could swing it!
I ended up right at 16% below msrp.
2012 m85. 32/16R transmission, Deluxe isolated open station,electro hydraulic and remote fender control, triple mid and rear SCV's, cold weather pkg, tires filled and H260 bucket.
They are saying mid march, MID MARCH - I cant wait - -I'll just wear my new JD hat that I got for xmas, I guess
Next question to figure - -Box blades, and front grapple buckets - -I also liked the thread on the top n tilt add on package -- seems like it might work. Will be maintaing forest roads and moving brush and logs- -amoung other chores
heck -I may just move a pile of dirt.... and then move it back
any links to those type equip threads would be great
the forum is great as I have been studying and reading in prep for the above tractor
thanks to all who participate!
   / 5083e and 5085m pricing? #12
Sounds like a pretty good deal to me:thumbsup: Looks like your pretty well getting the newer version of my 5410! Really good tractor.
Box blade is a must for dirt work, I'd get one with the hydraulic sacrificers if you can. The BB42 series:
JohnDeere BB42 Series Box Blades Landscape Equipment JohnDeere.com
Top and tilt is nice. I would look into one of them. There are a couple people on TBN who sell them. MtnViewRanch is a member here and has some high quality stuff. I do believe you can get them from the dealer/factory but I never have. It's always one of those things on the to do list. I'll either be buying a new tractor with one or putting one on my 3120 come spring.
As far as a grapple goes if your doing a ton of brush/log work they are definitely very handy. IMO Deere doesn't have the best factory grapples. I'd look for a good aftermarket one. Most of Deere's are the combo debris grapple and they don't work as well IMO.
I found I did a lot of pointless work whenever I got a new machine too, they are a lot of fun!
   / 5083e and 5085m pricing? #13
I have the Frontier root grapple and it is as stout of grapple as you can get and weighs a hair less than 1000 lbs. I've tried my best to tear it up and every piece of metal is still straight. We also run it on our skid steer that has over twice the lifting capacity of my tractor and it has held up there too.
   / 5083e and 5085m pricing? #14
Maybe I'm looking at the wrong things then. I still haven't gotten the new Deere website redesign figured out yet! I know I've seen them before but didn't see them when I just browsed through trying to find it.
Pheasantboy,
Did you get the SSQA on the loader - it is a must. Lot more versatility.
absolutely - -skid steer loader, for me was a must -needed to get a non john deere loader, it might not be green - -but it opens up a lot of possibilities
   / 5083e and 5085m pricing? #16
Took delivery of a 2011 5083e last month...ended up 16.5% off of MSRP..
newhope - I got a price on the 5083e and found the discount on the 5083e was better than on the 5m - -also, the dealer had less to work with me on the M series as far as financing as he said he needed to kick in more if I went 60 mo instead of 48 mo
not sure what all that means -but it told me they wanted to move more E sees than M series and not sure why
   / 5083e and 5085m pricing? #18
Yes...my dealer said the same..I never really seriously considered the m series...have an open station 6 cyl 2955 that still has a few farm years left on it and I farm with a 75 yr old relative and he has a 4620 for the heavy work....the cab was what I was after this yr...and hopefully getting him in a cab will keep him farming as long as possible...the 5083e is a great tractor..I shake my head and smile when I hear the black paint keeps em from this model...
   / 5083e and 5085m pricing? #19
The new 5083e is now all green and looks much like the M inside and out. The frame is still lighter, but a lot of upgrades. I wasn't fond of the black paint either, and was impressed enough with the upgrades to trade up. The 2012 is about $5000 more than my 2010 was.
   / 5083e and 5085m pricing? #20
Aggie...I totally understand your decision...most do like the "all-green"...I kinda like the black for some reason..I needed to make a new purchase before yr end to help cover some 1099 income taxes and the discounts and o%financing were too much to pass on...haven't seen a 2012 but will def be interested to see what they are...I moved my air seat rearward 3" and tilted the base 1" higher in the front...man, these 5e's are really good looking machines...I picking up another 60 acres of leased land for 2012 to keep me busy and lord willing with some rain have a better yr than 2011...I haven't heard a sole express regret in the purchase of a 5e,5m or 6 series tractor...great tractors the bunch...looks like the hard part is matching the right tractor to your needs without going overboard...
2461 (A60432)
2461 (A60432)
2017 Toyota Tundra SR5 Ext. Cab Pickup Truck (A59230)
2017 Toyota Tundra...
NIPPON HYD THUMB (A52706)
NIPPON HYD THUMB...
2022 NEW HOLLAND 266BMM 66-INCH BELLY MOUNT FINISHING MOWER WITH SIDE DISCHARGE (A57024)
2022 NEW HOLLAND...
2016 Bobcat E85 Midi Excavator (A59228)
2016 Bobcat E85...
2413 (A60432)
2413 (A60432)
