5093e Transmission problem
   / 5093e Transmission problem #21
I just purchased a 2014 5065e and have about 25 hrs on tractor and noticed gear whine in B3 and B4. These are the gears i seem to use 99 percent of the time, but have whine in other gears depending on rpm/ load. I run a 7ft heavy duty brush cutter, cutting hay 3 to 4 foot high and heavy. Running at 2300 rpms in b3 after hydrualics have come to full temps seems the gear whine is really bad, and gets worse when climbing hills/ putting load on gear drive train. Was going to let tell dealer and see what they have to say. Good luck with your repairs.
Could be the same issue. Mine had the noise since new but was only noticeable under high load at first. Eventually it got so bad I couldn't mow in b4 it was so loud and I could feel play in the driveline when applying /releasing accelerator. Took 1000 hours to get to that point though.
Best thing to do is get the dealer to check it out, at least then it will be on record in case something happens shortly after the warranty is out.
2006 CATERPILLAR 304C (A58214)
2006 CATERPILLAR...
Golf cart (A56859)
Golf cart (A56859)
PALLET OF MISC HOSE & PIPE INSULATION (A58374)
PALLET OF MISC...
More info coming soon! (A55787)
More info coming...
Rolling Steel Hoist w/Chainfall, 9' W x 12'H (A59076)
Rolling Steel...
Club Car Carryall Electric Utility Cart (A55851)
Club Car Carryall...
