50hr service..1/2 gallon short ..help.
   / 50hr service..1/2 gallon short ..help. #1
swampvol
SC
Kubota l3400HST TLB
Just finishing up my 50 hr service, and just noticed I miss counted how many gallons of udt I needed. I do have almost 3 quarts left in a container that I bought to re-fill after a leak.. The dealer is closed until Wednesday :( .
In short...I am lacking around a 1/2 gallon of kubota-UDT. Would it hurt any if I bought a gallon of hydro from the hardware store and mix it with the kubota-UDT?
Thanks...
   / 50hr service..1/2 gallon short ..help. #2
Thanks...
Depending on how much it holds I wouldn't even sweat being a half gallon low. That is considering that it is only that low. I'd just use it then top it off when I had the chance. Also... you never put in as much as it calls for. If, for example, it says 7 gal. capacity.... you will probably only put back 6 1/2 gal. I'm just making up numbers here but I'm sure you get the point.
Thanks, DmansPadge.
I maybe a little more short than a 1/2 gallon. After letting it run for a minute or two, the little round glass gauge no longer showed any fluid.
I got a little over 5 and 1/2 gallons back in, the book calls for 6.2 gallons....I guess those 2 filters suck up a pretty good bit.
   / 50hr service..1/2 gallon short ..help. #4
Excellent point.
When I replaced the UDT at 50 hours on my L3240, The manual said 11 gals but I only drained roughly 9+. And 10 gals topped it up to the full mark even after replacing both filters :)
So you may not really be short of UDT at all. Just fill it up till you reach the top line on the dip stick or run out of fresh UDT. If it is above the lower line you're OK til you can get more UDT.
Talon Dancer
Edit: Never mind. It sounds like you already did this and were still a little short.
   / 50hr service..1/2 gallon short ..help. #5
I probably would try to add some as soon as possible. It sounds like it will be a little too low. I was wondering what would happen if you over filled. I did this not too long ago and ended up sucking some out with a little hand pump. How much would too full hurt it?
   / 50hr service..1/2 gallon short ..help. #6
Thanks...
I would not mix fluids!!
   / 50hr service..1/2 gallon short ..help. #7
swampvol said:
...I maybe a little more short than a 1/2 gallon. After letting it run for a minute or two, the little round glass gauge no longer showed any fluid.
What did you plan on doing between now and Wed?
FWIW Most engines and trannies can actually run OK with a little less than the lower mark on the dip stick IF you are on level ground (to avoid loss of fluid pickup by the pump) and don't push them too hard (to avoid heat build up).
Talon Dancer
I had planned on clearing the outer perimeter of my fencing....dragging down no bigger than 1" 1-1/4" brush with the fel and box blade, then going back around it with the hog. No heavy fel work, but a decent 3-4hr run.
Lesson learned...check list, then check the list again..
   / 50hr service..1/2 gallon short ..help. #9
I have mixed Kubota UDT with compatable UDT hydraulic oil before and no leaks, mis behaving HST, catastrophic failures or any other problems.
I wouldn't have a problem mixing them.
   / 50hr service..1/2 gallon short ..help. #10
I had heard that Kubota UDT is multi-sourced - that means they buy from the cheapest bulk supplier and have it put into thier containers and labled as "kubota". Mixing in a gal is no big deal - after all you have more than a gal of old fluid in the FEL cylinders. But, don't use hydraulic fluid, use trans-hydraulic fluid that is meeting the UDT spec.
jb
2015 Ford F-750 Box Truck, VIN # 3FRNF7FA8FV745627 (A51572)
2015 Ford F-750...
Loftness Mulching Head (A51573)
Loftness Mulching...
(1) 14ft Tarter Gate (A51573)
(1) 14ft Tarter...
2014 Ford F450 Altec Bucket Truck (A52377)
2014 Ford F450...
2001 Trail King TK18LP / TK20LP / TK40LP Paver Special Trailer, VIN # 1TKC027231B046890 (A51572)
2001 Trail King...
18in Wain-Roy Tooth Bucket (A51573)
18in Wain-Roy...
