Backhoe 510 D won't move
   / 510 D won't move
Electrical isn't my strong suit so without a book I'm in over my head . I've read where it's possible the park brake switch could be the culprit , At least for the park brake / FNR fuse blowing. Machine is pretty clean and wiring seems to be protected well with looms and appears to be in good shape what I can see of it anyway.
   / 510 D won't move
Thanks again for the tips , Is there a way to bypass the whole electrical system and make sure park brake is backed off and run jumper wires to operate FNR just to try to get moved ? If possible that would be the deciding factor if it's electrical or mechanical . I can't hear or feel any click of the solenoids working on the reverser .
   / 510 D won't move #13
You should have a "cage" bolt that will manually release the brake.
Follow the PB line going to the housing in the axle and you seen a bolt with a jam nut on it. Screw that bolt in.
The clutch disconnect should have a 2 wire weather pack connector at the base of the loader lever. Un plug it and you can then; 1- check for continuity on the switch(should be open when released)(closed when depressed) 2- power to the switch.
The light on the dash is turn on or off by park brake pressure. It uses a normally closed pressure switch that opens around 150+/- psi, in turn turning the light off.
Flat Webbing Slings (A53316)
Flat Webbing...
Hyster S50XL (A47477)
Dixie Chopper LT2500 (A53316)
Dixie Chopper...
2015 Ford F550 Altec Bucket Truck (A52377)
2015 Ford F550...
Portable Restroom (A54865)
Portable Restroom...
2011 Ford Ranger Ext. Cab Pickup Truck (A55852)
2011 Ford Ranger...
