5103 hydro lift valve problem
   / 5103 hydro lift valve problem #11
I can not take credit for the following as I found it on another web-site. Please note the comment on wear eye protection!
"My 5103 with just under 400 hours did the same thing. I hooked up the brush hog and it would not go down. First I made sure the levers turned the respective shafts. The rest of the hydraulics worked fine. I figured a valve was stuck. The unit has a lock for the 3 pt., which also can control the rate of drop. It's under the seat on the right side, make sure it's not turned all the way in. I next put jack stands under the mower, then removed the seat. Seat removal consists of two 3/4" bolts, the seat needs to be moved forward and back to access them. I then blew off the dirt and crude around the housing, removed (slowly) the three allen screws hold the housing on. When the cover reaches a certain point, about 1/4" away from the transmission the pressure will release. Where eye protection! The jack stands allowed a very small amount of hydraulic fluid to blow out, otherwise the full stroke of the hydraulics would have blown out. Next remove both valves and look for rust, mine had rust on them, a very small amount that I was able to clean off with a rag. I put things back together and it worked fine. I feel the problem may lie with the super thin gasket they use, Moisture can get in and corrode the "dry side" of these valves.
The repair took 15 minutes."
   / 5103 hydro lift valve problem #12
I am having the same issue with my 2007 5103 JD the three point hitch is stuck in the up postion and I have read through these post hoping to find a solution before I hauled her to the dealership. Can someone help and let me know what the resolution was to this problem?
I had the same problem. I to have a 2007. I bought a new rock-shaft valve $670.00 but that did not fix it either. There was a nut that had came loose inside the housing not the valve (behind the valve on the rock-shaft). It was a $0.40 cent repair. This is not normally the case. The mechanic who is very good said that it the first one he had ever seen that had done that. It is normally the rock-shaft valve. I have one for sale ($250.00) because I bought a new one and installed it only to find out that was not the problem. There is also a guide somewhere on how to take the old one apart and clean/buff it. I think that the problem comes from condensation in the fluid, which creates rust if it sits for a long time.
2008 Hino 268 Truck, VIN # 5PVNJ8JV582S51513 (A57453)
2008 Hino 268...
RIPPER ATTACHMENT FOR MINI EXCAVATOR (A58214)
RIPPER ATTACHMENT...
INOP/NON-RUNNING 1999 Chevrolet Express Bus, VIN # 1GBJG31R7X1137055 (A57453)
INOP/NON-RUNNING...
Honda 24hp Brush Truck Pump (A57454)
Honda 24hp Brush...
2011 MAGNUM PRODUCTS LIGHT PLANT/TANK TRAILER (A58214)
2011 MAGNUM...
2021 UTILITY VS2DX 53FT DRY VAN (A59575)
2021 UTILITY VS2DX...
