5105 hydraulics lever one direction only
   / 5105 hydraulics lever one direction only #1
farmerracing
Hello,
I have a JD 5105 and one of the hydraulic levers now only goes one direction (down). By holding it down - the loader bucket goes all the way down and then back up again. But lifting "up" on the lever does nothing - and the lever itself does not physically lift as it used to, or compared to the other one. (the other lever works fine, both directions) Any ideas? Thanks much.
   / 5105 hydraulics lever one direction only #2
First, take apart the quick connects and put them back together. Try it again. That usually works.
Thanks I will do that, however it happens with all implements - lever "up" does not work.
500BBL WHEELED FRAC TANK (A58214)
500BBL WHEELED...
set of 4 tractor trailer tires Roadforce (A56435)
set of 4 tractor...
202483 (A54757)
202483 (A54757)
2018 Komatsu GD655-6 Motor Grader, S/N 60403, PIN# KMTGD032PJA060403, Turbo Diesel Engine, 14' (A59076)
2018 Komatsu...
2020 MACK PINNACLE (A58214)
2020 MACK PINNACLE...
2003 Big Tex 10PI...
