5210 fuse box cover? corrosion causing issues
   / 5210 fuse box cover? corrosion causing issues #1
dieselbeef
myakka city
bx2200..jd 2010 loader backhoe tractor
its overheating and some of it has melted..prior to my owning it.
is there a fuse box avail or at least a cover since mine is missing
the dirt and moisture getting in there Is causing problems and now the lights are not working
   / 5210 fuse box cover? corrosion causing issues #2
There was never a cover on the fuse box. Parts catalog in not listing a new fuse box, but you can get the electrical connectors to replace terminals in the fuse box. See item 21 in diagram. You can remove terminals from block one at a time and then cut them off and crimp on new ones. There are 2 part numbers for the replacement connectors depending on gauge size of wires. The 18-20 gauge uses 57m7507 and larger gauge wires use 57m7594. Other options would be to replace harness that would come with new fuse block attached or you can snip wires at back of damaged fuses and splice in individual in-line fuses. Last option looks ugly but it functions.
BTTL12 Mini Excavator (A47809)
BTTL12 Mini...
2018 Ford Explorer (A47307)
2018 Ford Explorer...
BTTL15H-6 Excavator (A47809)
BTTL15H-6...
2013 Kia Optima SXL Sedan (A46684)
2013 Kia Optima...
2012 SUMMIT FLARE STACK (A47001)
2012 SUMMIT FLARE...
Roll 6ft Chain Link Fence (A47809)
Roll 6ft Chain...
