5210 temp gage
/ 5210 temp gage #1
nickyterry
Gage goes all the way hot soon after start up have changed sender no help. any thoughts?
/ 5210 temp gage #3
Or maybe wire to sender shorted to ground? Disconnect and see what gauge reads.
/ 5210 temp gage #4
I did the same as you did. Replaced sender; no change. Then replaced thermostat. Finally put on an accessory temp gauge which showed the engine was normal.
Yes, I was told it could be gauge cluster, lead wire, or sender. Anything shorting to ground that gives a low ohm reading to the gauge will cause the gauge to think it is seeing overheating.
But there's another possibility worth checking.
I don't know if your model has an engine computer. We had the same symptoms on our 2008 JD310. Even though I thought it was an old fashioned mechanical injection because of having separate injector lines (not common rail) and no emissions control....well, it turns out that our model did have an early version of an engine control computer.
That are a known trouble spot, and the temperature gauge falsely showing hot was a known symptom of failure of the early engine control computers. Our dealer had a replacement in stock and said they all do it sooner or later.....said to be worse in models with the engine computer mounted to the engine or frame next to the engine.
rScotty
PALLET OF DISCHARGE HOSES MISC SIZES (A67714)
PALLET OF...
2015 Ford F-250 Ext. Cab Animal Control Service Truck (A66736)
2015 Ford F-250...
2006 Chevrolet TrailBlazer SUV (A66738)
2006 Chevrolet...
60" HANG ON PALLET FORKS (A65056)
60" HANG ON PALLET...
PORTA POTTY (A68842)
2018 GENERAC MOBILE PRODUCTS  MTL6S (INOPERABLE) (A67714)
2018 GENERAC...
