5252 electrical problem
/ 5252 electrical problem #1
OhioGuy
Platinum Member
Northeast Ohio
Ford 1220, Case 245, Cub SZ60, Cub 2284
My Cub 5252 recently had a failure of the hourmeter, tach and fuel gauge. The tach and hourmeter are blank, like no power. I was hoping to find a 3A fuse blown but no such luck, I checked, unplugged and plugged the harness to the dash, pushed wires around, still no go.
I thought someone might have experienced this?
The tractor still runs fine, hate to lose the hourmeter though.
The dash assembly is $300. I did download wiring diagrams and can identify the 12V supply to the dash, I probably should trace the ground also.
Thanks,
Curt
I discovered today that the PTO is also out. I found the wiring harness diagrams but really need the schematic. Does anyone have a 5000 series service manual they could scan the schematic from, I sure would appreciate it.
Or maybe it's online somewhere?
Thanks,
Curt
/ 5252 electrical problem #3
The service manuals for the 5000, 6000 and 7000 tractors don't have the wiring diagrams. According to the service manuals you have to order 772-9085A-CD from Cub Cadet at 1-800-800-7310 to get them. If I had a copy I'd post a link.
/ 5252 electrical problem #4
Thanks,
Curt
Hey Ohioguy, I have an 04 5252 and have exactly the same problem as you. I was having intermittent problems with the PTO. After cutting grass for a while the pto would not re-engage if I turned it off. Today my PTO started just cutting out while cutting. I noticed I was also losing power to the tach and fuel gauge at the same time. I think it must be caused by one of the other interconnects. I will send you a manual if you want.
Cub5K,
The manual would be greatly appreciated!
I rarely have my Cubs worked on by the dealer, but this time, I had them pick it up.
I just prefer to do that work myself, but I'm busy with a number of other things, so off it went.
I let it sit out overnight and when they came to pickit up, the tach, hourmeter and PTO were working again. I talked to the Cub guys the next day to tell them the electrical was intermittent and currently working and they hinted the dash and harness have a field correction, I'll let you know the outcome.
I had them take it anyway because the throttle won't hold and the muffler is broken at both header joints. I was planning on fixing the throttle (replacing the bungee cord to the choke to hold it) just couldn't find the time. This has been corrected by Cub twice under warranty?
So I'm using my backup mower, an 1872 and the first mowing I catch a root and break a gauge wheel. I fabricated a set out of PT lumber and ordereded replacements.
The second mowing, the regulator failed, and the grass is growing wildly....
But I am sure it could be a lot worse.
Cuz I'm still breathin in and out!
Thanks for the offer on the manual, I would greatly appreciate it!
Curt
Old Machinist,
Thanks for the suggestion, you sure do supply a lot of good advice and direction on this board!
I appreciate you taking the time.
Curt
/ 5252 electrical problem #7
Curt,
I would definitely like to know what they say the problem is with your tractor. There are so many interlocks that its hard to track them all down. The main clue that I can find is that I lose power to both the dash and PTO. I know I'm completely losing power because the dash goes dead and the PTO kicks off. When I tested today they both turned on and off every few seconds, just like a loose connection. They are powered separately from the ignition switch so my guess is either a bad ground or I'm losing power from the switch.
Let me know where I can email the manual.
/ 5252 electrical problem #8
Curt,
Forgot to mention about the muffler. My original one cracked and I welded it cause they wanted $130+ just for the muffler. I recently found a new one on ebay for about $60. It also cracked within the first hour. I think nex time I will make a muffler.
Cub5K
I sent you a PM with my email address.
Thanks,
Curt
/ 5252 electrical problem #10
Well my problem turned out to be a loose ground bolt. Cleaned terminals and tightened bolt and everything is good.
The Cub guys tell me the failure of the headers on the muffler basically cooked the dash.
They could consistantly get all functions with a new dash and limited or no function with the old dash.
I OK'd the repair and asked them to save the dash for me, I'll open it up, just out of curiosity to see if there is noticable damage.
They brazed the muffler and added some gussets to strengthen the joints, that's another design flaw in this tractor.
Hope to get it back this week.
Thanks,
Curt
/ 5252 electrical problem #12
Thanks,
Curt
Well I guess it was my turn. My PTO wouldn't kick in and I knew it wasn't a PTO adjustment. I traced power from the pto switch to the relay but I wasn't getting anything out of the relay. I remembered your post about the dash panel being your problem. Luckily I had a complete console that I picked up on ebay for 99 cents. I pulled my dash panel assembly and it was wrinkle melted on the side facing the muffler. I installed the panel from the spare console and everything is good. I suspect this damage happened before I opened up the engine compartment. To be safe I will be adding some heat proofing material to protect the dash.
2011 Ford F150 Pickup Truck (A64194)
2011 Ford F150...
2016 Ford Fusion Hybrid Sedan (A64557)
2016 Ford Fusion...
2011 JOHN DEERE 672G MOTORGRADER (A63276)
2011 JOHN DEERE...
2022 EZ-GO ELITE...
2016 CATERPILLAR CP44B PADFOOT ROLLER (A65053)
2016 CATERPILLAR...
TAYLOR 2R MULI-PASS HARVESTER (A64278)
TAYLOR 2R...
