'54 Ford stalls out on an incline
   / '54 Ford stalls out on an incline #1
monsonb
\'54 Ford stalls out on an incline
My grandfather has a 1954 Ford model NAA. (He doesn't have an internet connection; I'm posting this for him.)
The tractor runs fine except on inclines, then it stalls out on him. He can back up the hill in reverse without a problem, but can't make it up going nose first.
Thank you for any help you can give!
Brent Monson
   / '54 Ford stalls out on an incline #2
Re: \'54 Ford stalls out on an incline
Check the float level in the carburator. The Model T was like that also...... you had to back up hills if you wanted to get to the top.... /forums/images/graemlins/grin.gif /forums/images/graemlins/grin.gif
   / '54 Ford stalls out on an incline #3
Does it have a gravity feed fuel system?
How steep?
Egon
   / '54 Ford stalls out on an incline #4
As the junkman says chek the carb , seems to be a fuel problem when the tractor is in the nose up position. also check the fuel filter.
   / '54 Ford stalls out on an incline #5
You might find some useful information here.
   / '54 Ford stalls out on an incline #6
they are gravity feed systems......... another thought is that the tank might not have enough fuel in it to feed when at an angle. Depends on where the take off is located in the tank...
   / '54 Ford stalls out on an incline #7
Right side of the tank.. roughly int he middle, on an edge.
My guess would also be a float issue.. possibly even flooding it out.. etc. Or startving it if the float is 'heavy'
Soundguy
Thanks for the responses and the advice! I'll let you know what we find out.
Brent
   / '54 Ford stalls out on an incline #9
Does it have a Cork Float ? If not out of adjustment, could be laden with fuel...
Doc
   / '54 Ford stalls out on an incline #10
You could also check the settling bulb for air or water just a thought.
2012 DIAMOND CARGO FOOD TRAILER (A53843)
2012 DIAMOND CARGO...
20 ft. Shipping Container (A53117)
20 ft. Shipping...
TRUCKING INFO (A50775)
2007 Ford Crown Victoria Sedan (A51694)
2007 Ford Crown...
2016 Clipper Sport 106 17FT S/A Pop Up Camper (A51694)
2016 Clipper Sport...
2018 Ford Fusion Hybrid Sedan (A53424)
2018 Ford Fusion...
