54" MMM Fine Cut hieght adjustmenr
   / 54" MMM Fine Cut hieght adjustmenr #11
I worked with my deck until I got it pretty much perfect. When I moved to set the anti-scalp wheels, I found that three need to be in the 3rd hole from the top to be within the prescribed distance from the surface. The fourth has to be in the 4th hole. The deck is warped about 3/16" from the forming and welding processes. I certainly wasn't surprised to find that much warpage in a piece of metal that large that has been worked that extensively. It doesn't present a problem and the deck cuts perfectly.
well, FEL is off and the deck lines up perfectly when using the 3rd pin hole for setting 3.
Taking the FEL of though the first time was a bit challenging and I am sure it will get easier next time. :)
2008 DOOSAN G25 GENERATOR (A52472)
2008 DOOSAN G25...
5420 John Deere Tractor (A52384)
5420 John Deere...
2014 Kubota B2320 (A50123)
2014 Kubota B2320...
2013 Kenworth T800 T/A Dump Truck (A53117)
2013 Kenworth T800...
2013 Ford Edge Limited AWD SUV (A51694)
2013 Ford Edge...
Case TR270 Skid Steer (A52384)
Case TR270 Skid...
