54' NAA broken external hydraulic line
   / 54' NAA broken external hydraulic line #11
the #'s i gave you are cnh numbers. if you look on that page i linked it gives you some of the oring specs .. you *MIGHT* be able to get them locally if you have a industrial supply house .. etc.
I HAVE used a BIG multi- oring kit to do this before.. but it wasn't a 10 size HF kit. it was a kit with probably a hundred different size orings.. and I found suitable ones.
I'm not sure if the regular naa hyd top cover and oring kit contains those or not ( 13$ kit )
but anyway. you have the part numbers if nothing else. and the descriptions if you hit that page.
good luck
2020 INTERNATIONAL LT625 TANDEM AXLE SLEEPER (A54607)
2020 INTERNATIONAL...
2015 PETERBILT 365 (A52472)
2015 PETERBILT 365...
2005 TerraGator 8104 (A53473)
2005 TerraGator...
2020 KUBOTA RTV...
2018 MACK CHU613 DAYCAB WINCH TRUCK (A53843)
2018 MACK CHU613...
