Richard
Elite Member
- Joined
- Apr 6, 2000
- Messages
- 4,997
- Location
- Knoxville, TN
- Tractor
- International 1066 Full sized JCB Loader/Backhoe and a John Deere 430 to mow with
I've always been confused by this.
The blades on a "540" rated cutter will rotate at a certain RPM. Do the blades on a "1000" pto cutter rotate at the SAME RPM that they do on a 540 pto? Twice as fast?
I understand there is more power avaialable through the 1000 pto shaft. Is that similar to say, gearing on a car? Meaning, the tractor spins say two shafts, one at 540 and one at 1,000.
If the BLADE rpm is the same on BOTH (and I don't know if that's the case), then the 1000 shaft is turning the blade gearbox at roughly 1/2 speed that the 540 is turning IT'S blade gearbox. I'd equate that to being in a car in first gear under load, verses 3rd gear under load. Lower gear, easier to transfer power.
Do I finally get it?
