5400 brake issue
/ 5400 brake issue #1
Brokenheart
Cat
My brother has a JD 5400 with around 4000 hours and the brake pedals goes to the floor. We tried bleeding them and can get good pedal but it doesn稚 last.
Any help would be appreciated
/ 5400 brake issue #2
Do you notice a difference in the pedal from when the tractor is hot compared with cold? I ask because my pedal suddenly went to the floor but only when the tractor was hot. Turned out to be a very slightly stuck remote lever. We solved it by used a laser thermometer on the rear axle and checking the temps. They were getting way hotter than expected and it was the remote lever. I never expected that was the problem.
/ 5400 brake issue
It doesn稚 matter if the tractor is warm or cold. The pedal goes to the floor. While bleeding the brakes you can get good pedal but within a couple of minutes it goes back to the floor.
/ 5400 brake issue #4
I do not know that answer. Maybe call a Deere service shop and ask if they can point you in a direction? That's worked for me over the years.
/ 5400 brake issue #5
I would start by capping the brake lines. If the pedals still do not hold the brake valve needs to be rebuilt.
If they do hold, then I suspect the O-ring(s) on the brake operating piston(s) (one each side) inside the rear axle have failed.
Try capping each side separately and test, it might be only one side (left/right) bad.
/ 5400 brake issue #6
Do the pedals go to floor if they are both pushed together or separately? If only separately, the pedal stop screws may need adjustment.
/ 5400 brake issue #7
I agree with jd110. My 2350 was doing the same thing. If I push the pedal down slowly it would always go "to the floor". If I quickly pumped it once or twice it would hold pressure.
My pedal return stops were out of adjustment.
