Dealer 5425 On Dealer Lot
   / 5425 On Dealer Lot #1
downslope
Platinum Member
NY
MF TO-35, Ford(s) 2000, 8N, 9N, White 2-70, NH TD75D, JD 5045D
I've seen a new open station FWD 5425 on local dealer's lot. It has 3 remotes in the middle, two at the back and a power reverser transmission. The tires are 28" R-1, no weights. How much do you think I should expect to pay for this configuration? It's now considered a prior model, is that right, replaced by the 5 series? Which of the new 5 series would configure closest to this particular 5425?
   / 5425 On Dealer Lot #2
all depends on where you live. is this a rental return perhaps or does it have 0 hours? comparible 5 series tractor would be a 5075M.
Not a rental return, it is zero hours.
   / 5425 On Dealer Lot #4
How much are they asking?
D.
D.
They are asking what I think is too high, in the high $30's way beyond $35K.
I may be wrong, but I would think that kind of price would be more in line with a cab 5425. I only inquired briefly when I stopped in to order some parts. The salesperson did indicate a willingness to compete to some extent with other makes in the area and suggested I come back and see the manager who was out that day.
We have several other brands around but the next JD is over 100 miles. I could probably get a Kubota 7040 equipped similar in the $29K range, maybe a little less for an equivalent NH TD or CaseIH Farmall. I was thinking the open station JD should be in the low $30's not the high end of that decade. I suppose I can always make an offer if I don't pick up something else.
   / 5425 On Dealer Lot #6
High 30s seems way out of line.
I bought my 2005 JD 5525 cab 4wd for $41K new.
D.
   / 5425 On Dealer Lot #7
The 5075M configured as closely as I can to the OP's description of the 5425 is $40,495.
   / 5425 On Dealer Lot #8
This should help a bit--In Aug 08 I bot 5325, open station, 4wd, 3 remote back, 522 loader, power reverser 12x12 for 37,100. The third remote was added at the dealer. The 5325 has a different motor than the 5425. I priced 5425 at the time, but, sorry, I can't remember the difference in the two models.
   / 5425 On Dealer Lot #9
If I'm not mistaken, it was about a $1,300 to $1,700 jump in price to the next step. Might have been a bit more between the 5325 and the 5425 versus the 5425 and 5525.
2024 John Deere 35 P Excavator (A53485)
2024 John Deere 35...
2019 Dodge Durango (A53421)
2019 Dodge Durango...
2017 Chevrolet Tahoe SUV (A55853)
2017 Chevrolet...
2000 Ford F-250 Pickup Truck (A55852)
2000 Ford F-250...
Krause Dominator 4850-18ft (A57024)
Krause Dominator...
2024 KMC 7406 (A53084)
