5425 Tractor
   / 5425 Tractor
Had john Deere out and pressure tested the clutch , clutch is bad , have the tractor almost split , parts here sat....
   / 5425 Tractor #14
Never seen a electrical clutch
The clutch isn't actually electrical, it is electrically activated by a solenoid that directs oil pressure to engage the multiple disc wet clutch.
   / 5425 Tractor
Yes , should have explained further , it has a froward solenoid and a reverse solenoid actuated by a rehostat on the clutch pedal instead of the traditional cable setup....more stuff to go wrong....JD says when you lose both for/rev usually means the clutch is out. Mine all the springs were in the bottom case. Took about 9 hrs to repair including removing/installing loader.
   / 5425 Tractor #17
PR still working good ?
How many hours on this JD ?
PAIR DIAMOND PLATE DBL AXLE FENDERS (A51247)
PAIR DIAMOND PLATE...
New Holland TN65S (A50123)
New Holland TN65S...
2007 GMC C4500 Mechanics Truck (A52384)
2007 GMC C4500...
SHOP BUILT 96" X 25' TRI AXLE GOOSENECK TRAILER (A51247)
SHOP BUILT 96" X...
UNUSED FUTURE HYD 12" AUGER (A51248)
UNUSED FUTURE HYD...
2016 Chevrolet Silverado 3500HD Knapheide Service Truck (A51692)
2016 Chevrolet...
