55 gallon drum bbq smoker
   / 55 gallon drum bbq smoker #11
Think I can see your plan. You say horizontal, but do you mean vertical? It sounds cramped with 1/3 from the top then 1/2 down from from that and 1/3 again down If you make it a long horizontal then you are planning to put the fire at one end of it right? Not all along the bottom. With barrels either standing on top of each other or lieing next to each the fire has to the farthest point from the food so it is smoked and not cooked/grilled. As long as your fire box is at one end and the food is at the other or far enough away that it won't receive direct heat your good to go. The only problem I see with the horizontal set up is that the smoke/heat will travel along the top of the barrels as it moves across and out the smoker making for some uneven cooking. Where as if they are welded end to end and standing vertical, up and down, all the racks will recieve even smoking and heat as it travels up from the bottom that and out the top of the smoker. With them vertical and the fire in the bottom you will have a 3-4 foot space between the fire and the racks of food, but all the food recieve the smoke and heat evenly. Don't for get to flip the food every couple hours or so if you set it on racks rather than hanging it.
   / 55 gallon drum bbq smoker #12
I think you're confused about what a smoker is. Then again, shopping at sams club doesn't help. The only smoker you can buy at sams club is a little chief type smoker. Smoking is done at very cool temperatures for very long periods of time. We're talking smoked salmon and jerky. If you want to cook ribs, and shoulers then you will liekly be barbecuing. Barbecuing takes place at temps between 200 and 250 and will get a rack of spare ribs or baby backs done in a few hours. Takes a chicken 3-4 hours and beef chuck 5-8+ hours. The vertical offerings at sams club looked like a rounded off barrel right? This is marketed as a water smoker but is designed to cook at 200-250, hence the water pan that boils at about that temperature as all water does. You are wanting to build a barbecue. Not a grill, grills are hotter and a good example is the weber kettle. Spend some serious time at the barbecuen site and I think you will see with what I am saying.
Next thing is to build your own bbq with character. The pits you see on trailers, at cookoffs, and making pulled pork are indeed barbecues. Almost every one of them uses an offset or separate fire box. They do this to control temperature and to be able to add fuel without disturbing the meat. Replicate this design. Your coooking box can be horizontal or vertical, doesn't really matter since the whole thing will be like a big oven, think about how much meat you want to cook and how you want to arrange it. Most are horizontal to give a single large grate. Build your bbq so the grate is at a pleasant height.
Your firebox will need to be big enough that you are not constantly adding fuel. It doesn't need to be as big as a 55gal bbl. Half that is still pretty large. You need to make it airtight so that you can choke the air off and the big bed of coals will put out consistent heat for a long time. A big slow burning bed of coals will allow you more time to drink beer. A sign of an inexperienced bbqer is the constant smoke from the stack, you want dry heat, not a smoldering log. I find plenty of pink color and flavor smoked into the meat without seeing much any smoke at my stack.
A great fuel is lump charcoal or charcoal briquettes. You want dry heat from wood and you won't get that from propane. Another option is plain wood but you don't wat to cook on it until the wood has cooked down into a glowing mass of coals so you need to have a separate fire pit beside your bbq to cook down the wood.
I''ll attach a pick of my setup. The base is store bought and cooks real well. I made some changes as I saw fit.
2013 MACK GU (GRANITE) (A52472)
2013 MACK GU...
2013 Nissan Titan Ext. Cab Pickup Truck (A51692)
2013 Nissan Titan...
2010 POLARIS RANGER 4X4 4 SEATER UTV (A52576)
2010 POLARIS...
2013 3400QB SUNDANCE 5TH WHEEL CAMPER (A52472)
2013 3400QB...
2009 International Frazer Bilt X-514 Ambulance (A52377)
2009 International...
2015 DODGE RAM...
