5500 cold hyd. dead until tractor op is reached.
   / 5500 cold hyd. dead until tractor op is reached.
Thanks guys, for your thoughts. I was under the impression that I could tell by the clarity of the oil if it had water present. I know if you blow a head gasket and get water in the engine oil, you know it by the milky color of the oil. I was using the same logic. I will get this crackle test done asap. I now tend to agree that water must be my problem. I found the location of the pickup screen but have not checked it yet. I'm going to get my test oil from this port on the tractor.
P.S. 8deg. F. here tonight.
   / 5500 cold hyd. dead until tractor op is reached. #12
Take your oil sample from a low point if you can, I have put a spoon-full of oil on a piece of aluminum foil, using a small flame to heat from the underside. The water will boil right out of the oil and sputter a bit. But water should make the oil look a bit cloudy and dull looking, not the usual bright shiny look.
2016 Chevrolet Tahoe SUV (A52377)
2016 Chevrolet...
Light Tower (A52377)
Leeboy 8500 Paver (A47477)
Leeboy 8500 Paver...
2025 K1230 UNUSED (10) Wire Mesh Netting Rolls (A53117)
2025 K1230 UNUSED...
2018 KENWORTH T800 DAYCAB (A53843)
2018 KENWORTH T800...
2007 INTERNATIONAL 4200 SBA 4X2 BUCKET TRUCK (A51406)
2007 INTERNATIONAL...
