Price Check 5520/5530 Price
   / 5520/5530 Price #1
Blee25
Frankfort Ohio
2008 John Deere 5203 fwa loader, 1949 Farmall Cub, 1995ish Craftsman riding mower
I am considering moving up to a small ag/utility size tractor. I am looking at tractors like the John Deere 5103/5203, New Holland tt60a, and Kubota M4800. I am condsidering taking a drive to check out Mahindra and am wonder if I can expect them to come in under the other price wise? It appears that the John Deere 5203 with 4wd and quick attach loader can be had for about $24,000 and the 5103 for $23,00. Just wonder if it is worth the drive to check them out.
   / 5520/5530 Price #2
Don't know here you are from and how far you need to travel to see a Mahindra. But for me I am completely safisified with my Mahindra 3325. It was less expensive than the JD of Kubota by a mile for the same HP. I do think my tractor is heavier and more has steel than plastic. But the 3325 and 3525 are older designed tractors. I would for sure look at them if I were you. Only short side is name recogination. Deere and Kubota are still stronger here. But the name doesn't do the work.
Don
   / 5520/5530 Price #3
the 5530 w/ FEL should come out close but not sure about the 5520.....it all depends on your location also. I would compare the specs on the Mahindra's vs. JD, Kubota, etc.....
   / 5520/5530 Price #4
The Mahindra 5530 will probably be similarly priced but are quite a bit heavier duty tractor. Compare the weight of the tractor and the lift capacities.
2021 Chevrolet Silverado 1500 4x4 Crew Cab Pickup Truck (A56858)
2021 Chevrolet...
(INOP) YAMAHA GAS GOLF CART (A58374)
(INOP) YAMAHA GAS...
2012 Ford F-550 Ext. Cab Stellar EC3200 1.5 Ton Crane Utility Flatbed Truck (A55973)
2012 Ford F-550...
2022 Ford Explorer 4WD SUV (A56859)
2022 Ford Explorer...
2007 LUFKIN END DUMP (A58214)
2007 LUFKIN END...
2019 FREIGHTLINER WATER TRUCK (A58214)
2019 FREIGHTLINER...
