5530 and rotary cutter size...
   / 5530 and rotary cutter size... #11
Amstaff,
Yes. First two years no loss of gear oil.
idaho2
Idaho2,
Did you opt for the chain guard?
Amstaff
   / 5530 and rotary cutter size... #13
Couple more pics...
The overgrown pasture was loaded with thistle over 6' tall. The tractor/mower cut right through everything without flinching. This was different then when I used my Kubota L4400 which would bog down in the heavy stuff. With the Mahindra, I could simply set the RPMs and go with no worries.
View attachment 276176View attachment 276177
For your sake, I sure hope I'm not looking at Canada thistle.
   / 5530 and rotary cutter size... #14
Amstaff,
No. Plan to order next spring. Cost about 800.00 for both front and rear.
idaho2
Not sure what kind of thistle it is. After a quick search, it does not appear to be Canada thistle. I can tell you it was over 6' tall in places and has spikes all over it. Not fun to work in. Maybe Scotch thistle? I think I mowed everything, but I'll look and see if there is a survivor or two that can help me I.D. it.
Amstaff,
idaho2
When mine was delivered, I had asked about the chains. I was told that the front and back were somewhere around $160 each. He did not have his info in front of him, so he could very well be way off on his estimate. I will give him a call tomorrow and ge ta better idea.
   / 5530 and rotary cutter size... #17
If your sales person is possibly correct I'll be needing to talk to them.
   / 5530 and rotary cutter size... #18
Canada thistle will have side shoots which run in a horizontal fashion, and the smallest piece broken off when cultivated, will reproduce. Canada thistle is the only member of the family which doesn't have a typical root system. From the picture you posted, I don't think it is Canada thistle. Canada Thistle
Well, no need to get in touch with my guy... I called this morning to have hime look up the cost of front and rear chains. He was way off on what he guessed when he delivered the Kodiak! $485 for the front, $375 for the rear!!!! Ouch.
   / 5530 and rotary cutter size... #20
Amstaff,
That confirms the price I was quoted out here plus shipping. Since the holes are already on the mower, I think I need to get a stick welder and make my own. I'll buy the chain from a rigging supply shop and have the links cut to length, weld to angle iron and mount to the mower. I know I can do all this for less than total cost of the ready to mount set up.
Does your dealer have a set that you could see. I need to have a link length count and the size. 1/4" or "?". Then I can build it. Better yet, does anyone have a close up photo of a set.
idaho2
KENWORTH T/A DAY CAB ROAD TRACTOR (A57192)
KENWORTH T/A DAY...
2014 Gravely 60" Zero Turn mower (A55973)
2014 Gravely 60"...
2004 Ford F-550 Miller 301 Wrecker Truck (A55852)
2004 Ford F-550...
UNVERFERTH 330 - 19-INCH EXTENSION KIT FOR RIP-STRIP TOOLBAR PART # 63186G (A55315)
UNVERFERTH 330 -...
MILWAUKEE 14" Abrasive Cut-Off Machine (A59076)
MILWAUKEE 14"...
LOT: (7) Wheel Loader Shanks (A59076)
LOT: (7) Wheel...
