55gal drum cleaning help needed.
   / 55gal drum cleaning help needed. #1
bnixon
Houston, Texas
TC33D / 7308 ldr 60" HD bucket
I have just been given a 55 gal drum that had hydraulic oil for a elevator in it. I was wondering what is the best way to clean this thing out before I put diesel fuel in it?
thanks,
   / 55gal drum cleaning help needed. #2
I think I'd just drain all the hydraulic oil out that I could, pour in a couple of gallons of diesel, roll it around awhile, turn it end over end a time or two, then drain that out (and use it to burn the next brush pile). I think if there's any oil left in the barrel after that, it would be so little you'd never know the difference after you fill it with diesel.
   / 55gal drum cleaning help needed. #3
<font color="blue">...what is the best way to clean this thing out ...</font>
Hey Buddy... got a match... /forums/images/graemlins/laugh.gif
Just kidding... I agree with Bird's method... /forums/images/graemlins/wink.gif
(then get a match.../forums/images/graemlins/tongue.gif)
   / 55gal drum cleaning help needed. #4
/forums/images/graemlins/tongue.gif As long as you are doing it, how about putting in a piece of clean CHAIN which will drag around inside the drum and scour off the little cruddies that may still be clinging to the inside. /forums/images/graemlins/crazy.gif
   / 55gal drum cleaning help needed. #5
Sounds like a lot of work. My oil distributor has used diesel drums for free; I had a brand new tractor when I got mine, so I opted for a brand new drum - $20, and he'll give me the $20 back if I don't want the drum any more.
Thanks guys!
I will give it a shot this weekend /forums/images/graemlins/laugh.gif
I just didn't know if I needed to put any type of cleaner or anything in it like simple green or something?
   / 55gal drum cleaning help needed. #7
</font><font color="blue" class="small">( if I needed to put any type of cleaner or anything in it like simple green or something )</font>
I sure wouldn't. If you do that, then you'll have to wash that out with water and then wait on the water to dry thoroughly before putting diesel in it.
Thanks again Bird!
I will just use the diesel fuel and forget about the cleaner /forums/images/graemlins/blush.gif.
thanks,
   / 55gal drum cleaning help needed. #9
ditto birds post and even that's probably overkill. The little bit of hydraulic fluid mixed with 55 gal of diesel wouldn't even be noticed, and would just burn right up but birds method would remove any doubt.
   / 55gal drum cleaning help needed. #10
</font><font color="blue" class="small">( even that's probably overkill )</font>
I agree. /forums/images/graemlins/grin.gif Just like to be real sure. /forums/images/graemlins/wink.gif
Farm Hand Silage Wagon (A50515)
Farm Hand Silage...
2005 CATERPILLAR 12H MOTOR GRADER (A51406)
2005 CATERPILLAR...
UNUSED JCT QUICK ATTACH BACKHOE DIGGING ARM (A51244)
UNUSED JCT QUICK...
20' One Trip Shipping Container (A50514)
20' One Trip...
UNUSED FUTURE MINI EXCAVATOR HEDGE CUTTER (A51244)
UNUSED FUTURE MINI...
Kubota SVL65-2 Open Station Rubber Block Tread Skid Steer (A52128)
Kubota SVL65-2...
