5740 steering wheel leaking
/ 5740 steering wheel leaking #1
athomp
My 5740 has started leaking oil from hub of the streeing wheel. Anybody know what up with that or how to fix it?
/ 5740 steering wheel leaking #2
It sounds like the orbital valve is going bad or the shaft seal leaking.
It's the hyd. valve that the steering wheel connects to that operates the steering.
I had one go bad on an old International tractor we owned some years back.
In my case, the best I remember, I had to pull the steering wheel, remove 2 hyd. lines, and couple of bolts that held the valve in place.
I sent it off to a hyd. rebuild shop and in a week or so got it back, reinstalled it and all was good.
You may want to look for other signs of leakage in the steering wheel area under the hood to be 100% sure.
/ 5740 steering wheel leaking #3
If you mean its leaking around the top by the steering wheel then it is probable just the top seal. Or at least thats what it was on my ford.
2006 KOMATSU FD80T-8 FORKLIFT (A67148)
2006 KOMATSU...
2017 FREIGHTLINER CASCADIA 125 6X4 T/A SLEEPER TRUCK TRACTOR (A67147)
2017 FREIGHTLINER...
GYRO TRAC GT-25 FORESTRY MULCHER (A65053)
GYRO TRAC GT-25...
JOHN DEERE LOADER MOUNT QT BALE SPEAR (A64278)
JOHN DEERE LOADER...
2014 Chevrolet Tahoe SUV (A64194)
2014 Chevrolet...
Big John Semi Trailer (A65640)
Big John Semi...
