5E Limited vs. 5M
   / 5E Limited vs. 5M #11
If you plan to farm or work the tractor hard I would recommend an m a 6d or take a good look at the Massey 2680. I like my 5093 but as I found out it was never meant to be a farm tractor, it is built and marketed to "property owners" and I wonder how it will hold up.
   / 5E Limited vs. 5M #12
I had a 2010 5083e and traded up to the MY2012 5083e a couple weeks ago. All the creature comforts that seperated the M from the E in 2010 are fixed in the MY2012. Except for electric 4x4 activation and throttle, the cabs are essentially the same. . . At first glance you will swear you are looking at an M. . .
Not quite.
The e still doesn't have the electro-hydraulic 3pt hitch control. That's a HUGE difference, especially if you've ever tried to hook up to a hay mower by yourself, etc. And, there are still mechanical differences, 3pt hitch lift capacity, engine performance, etc.
The M is still a "premium" tractor, and the e is an economy. You can't make a silk purse out of a sow's ear. :D
And, the OP stated that he wanted a tractor do work a "hay operation." That's what I do. I chose the M and still think it's the best choice for the intended purpose.
   / 5E Limited vs. 5M #13
The bigger hydraulic pump on the 5M is a added bonus when lifting up big bales with the loader.
   / 5E Limited vs. 5M #14
Not quite.
No doubt the M is a much heavier built tractor, but I was refering to the cab and the upgrades from 2010. We put over 10000 hrs on a Deere 2640 in the hay field and it is still in operation. The E is very similar to the 2640 in frame size and I expect the same longevity.
   / 5E Limited vs. 5M
I'll add some details to my original post. The land is already broke. I intend to use a tiller to prepare the seed bed and seed with a disc drill. I'd like to cut the hay with a Moco and I'll only make square bales.
The berry harvester only needs 30 pto hp and I'd like to get a side discharge manure spreader to mulch the Saskatoons.
Right now I have nothing but a JD 2520 that I use for my Apiary.
   / 5E Limited vs. 5M #16
AGGIEOO;
I've had the opportunity to use my neighbor's 2640 during the past 2 years. Great tractor and just the right Hp/Size machine for my hay operation!
One thing that really stood out.... look at the transaxle housing on the 2640. It has the same squared off axle casting's that the M does. Very beefy, heavy duty! :thumbsup:
Considerably different than the Limited's.
AKfish
2012 KOMATSU GD655-5 (A52472)
2012 KOMATSU...
New Skid Steer Attachment Plate (A53002)
New Skid Steer...
New/Unused 10ft 40 Drawer Workbench (A51573)
New/Unused 10ft 40...
2016 Ford Explorer AWD SUV (A51694)
2016 Ford Explorer...
AGT Mini SkidSteer (A50322)
AGT Mini SkidSteer...
2013 FREIGHTLINER M2 ROUSTABOUT TRUCK (A52472)
2013 FREIGHTLINER...
