5v steel roofing
   / 5v steel roofing #1
randy41
Veteran Member
Linden VA
you know the stuff. any reason not to just flip it over when one side gets rusty?
   / 5v steel roofing #2
The v's will hold the metal away from the supporting boards.
   / 5v steel roofing #3
yup... might be ok on a roof over a bale of hay or something... but i wouldn't do it on a barn.
   / 5v steel roofing
just a thought i had while (you guessed it) i was putting used 5v roofing on my little shed. you could put the screw in the v...right?
   / 5v steel roofing #5
sure.. you CAN screy it down.. it just won't set flat on the purloins and runners.. it therefore may not seal end to end, and may rattle in the wind.. etc. if it is a single long piece for the runs.. may make less of a difference.. especially if it is just a top cover, open sided structure on the cheap.
   / 5v steel roofing #6
I have seen commercial buildings done this way, but only on the walls. This was 26 guage steel.
Dave
TEST BID LOT (A50775)
1986 ASPT 30ft S/A Pole Trailer (A51692)
1986 ASPT 30ft S/A...
2021 Delta Redirective Crash Cushion 75000 (A51692)
2021 Delta...
Year: 2017 Make: International Model: DuraStar 4300 Vehicle Type: Truck Mileage: 45,026 Plate: Body (A51692)
Year: 2017 Make...
2019 Dodge Challenger GT AWD Coupe (A51694)
2019 Dodge...
2009 MACK GRANITE (A52472)
2009 MACK GRANITE...
