5w-30 instead of 10w-30? Amsoil?
   / 5w-30 instead of 10w-30? Amsoil? #1
RanchMan
Platinum Member
Texas
Mahindra 4110
Looking at changing the oil in my tractor soon. The book says 10w-30 CD/CE. Amsoil has a 10w-30 rated as "CF" (which is supposed to be ok to use in place of CD oil).
Sent Amsoil a message, they responded recommending their 5w-30 CH-4 oil.
My question: Is there a problem going to "5" instead of sticking with "10"?
BTW, haven't heard back from the tractor manufacturer yet.
   / 5w-30 instead of 10w-30? Amsoil? #2
RanchMan, sounds like Mahindra is as far behind on updating their manuals as Kubota is./w3tcompact/icons/wink.gif The CC/CD rating is definitely obsolete (can't say for sure whether you can still find CF), but the CH-4 is the latest rating. The first letter "C" means it's for compression combustion engines (diesel) and the second letter tells you how "modern" it is; the higher up the alphabet the better. I certainly doubt that you'd ever have a problem with that 5W-30 oil and if you were in a cold climate, it would be even better, but in Texas? . . . . I'd go with a 15W-40 oil, CH-4 rating, if it were me.
   / 5w-30 instead of 10w-30? Amsoil? #3
Ranch Man, What equipment are you running AMSOIL in ?I use the AME 15w40 ($15.35 Gallon) v/s the HDD 5w-30that cost ($24.90 per gallon) and I have had excellantresults. I use the AMSOIL AME 15w40 even when the manufacturercalls for a 10w30 (No Problems). AMSOIL Dealer: AmericanMadeOil.com
Bird-
You got that right on regarding the out of date manuals! /w3tcompact/icons/smile.gif
DoNotTreadOnMe-
Well, currently I haven't run Amsoil in anything - just considering it. I have found Kubota brand 10w-30 and Shell, but, but otherwise it seems pretty hard to find. Just thought I might try synthetics.
   / 5w-30 instead of 10w-30? Amsoil? #5
I have been running the Amsoil Series 3000 5W-30 in my JD 4700 for the last 60 hours with no problems. I also ran it for over 200 hours in my 96 JD 955 before I sold it. I run it in my 97 Ford Powerstroke also that has 500+ HP.
In my opinion it is one of the best HD oils out there. It makes the engines run smoother, especially in the cold winter months.
2019 MACK PINNACLE P164T DAYCAB ROAD TRACTOR (A51406)
2019 MACK PINNACLE...
2012 PETERBILT 388 DAYCAB (A53843)
2012 PETERBILT 388...
kids dirt bike (A53424)
kids dirt bike...
Year: 2017 Make: Dodge Model: Grand Caravan Vehicle Type: Van Mileage: Plate: Body Type: 4 Door V... (A53424)
Year: 2017 Make...
2011 New Holland B95B Cab MFWD Loader Backhoe (A55218)
2011 New Holland...
2025 MS380R Mini Stand-On Track Loader Skid Steer (A53421)
2025 MS380R Mini...
