Diamondpilot
Super Star Member
- Joined
- Jan 18, 2007
- Messages
- 16,316
- Location
- Daleville, IN
- Tractor
- Jinma 254/284 Ford 861 Powermaster at work
Significant truth to that idea. While additives can be replenished, it is the viscosity improvers that actually shear and break down. You are correct, the base oil itself doesn't break down. But VI are in a class by themselves compared to additives that control oxidation, soot control, etc and those that act as detergents and such. One can replenish those, but one cannot just replenish viscosity improvers. They are an integral part of the motor oil as it was developed. The only way to make an oil longer lasting in that regard, is to have a base oil that significantly reduces the need for VI. But to do that, even with PAO Group IV synthetics, you greatly restrict the limits of the cold flow. For instance, while there are many PAO full synthetic 30w oils that qualify as 10w30 on their own without any VI, as you go to something like a 5w30 and even further with a 0w30, the use of viscosity improvers is the only way to get to those low cold flow levels. And filtration or additive replenishment will never compensate for such things a fuel dilution. So either via fuel dilution or VI shearing, once an oil goes out of grade, it has to be changed.
My ex father in law, who worked for Pennzoil, said the biggest factor on modern vehicles that increased oil life and engine life isAIR filtration.
Makes sense. All a engine is really is a air pump. The vehicles up to about the 80's has crappy air filter systems. Today's small engines up to heavy equipment have very tight air filtration systems.
Chris
