6 foot lawnmower needed
   / 6 foot lawnmower needed #51
something to think about.... a regular old riding lawn mower, or garden tractor, even some zero turn mowers. once your mow with them, and then get off of them after about 10 to 20 minutes or more, your entire body tingles some after you get off the tractor. from the vibration of the engine itself going through your body. a regular 2cycle chain saw or weed eater, you can feel vibration in your body as well after using them.
one thing i like about the old 1950ish allis chalmers CA with 72" woods belly deck, you can be on it all day and get off of it, and never feel a thing like you do from riding lawn mowers. the only thing i wish it had was power steering *arghs*
your SCUTS and larger zero turn like mowers, more likely give much less vibration, due to engine size and how the engine is mounted to the frame.
i am going to push that you also check out other manufacture mowers and tractors, for nice seating on. every beast is built slightly different, some units work better for shorter folks, and some units work better for tall folks. example most ladies i know are shorter than all the men i know. and blocks of wood on pedals have been used, to pillows under there rears to set them high enough above the hood, etc... while taller folks complain about being cramped and muscle spasms having to be all cramped up on some units and not being able to drive a given unit for any length of time.
some seats will not move forward enough or move backwards enough, some seats simply set to high, some seats simply don't have enough spring strength for weight of person. at times i wish there was better adjustable seating options like comes in nearly every vehicle now a days, to both forward/backwaord, up and down, and even lean the seat, and adjusting stearing wheel up down, in and out. to simply having arm rests that adjust to correct height or out far enough for the operator/driver.
some units the pedals (break/gas/etc..) can be adjusted to fit the operator better, vs having to come up with some invention or thing to work out for operator.
with above i hate all the "re branding" that gets done with manufactures these days, everything the same on some units but a different color and logo, while others slight different hood shape, and perhaps different default tire type but placed under a different manufacture name. perhaps a different warranty plan or some other garbage. perhaps a different grip on levelers and pedals, and perhaps a different type of seat. all these marketing schemes. *shakes head* ughs
Prosperity, I was wondering why they didn't still offer a 62 vs the 60 on a mower this size and this cost...maybe clearance on 4ws?
Boggen, you bet, and likely the vibration of the same engine in a garden tractor vs SCUT could be more; just less mass to absorb it.
I was very, very happy with the kawasaki gas engined JD lawn tractor I had until recently when I gave it to a friend as a housewarming present for his retirement home.
but it did not have power steering and it meant too much gripping and tugging. Going with a 2wd vs 4wd should mean less machinery for the power steering to move around so I'm hoping the steering will have a light touch.
JD has been making the same thing for a long time now and yes they charge a lot for their mowers but I think there's a lot of trickle down tech and refinement one at least gets for the money.
my thought process on this really focused when I realized I could add a wing mower to just about anything, and wing mowers are perfect for getting under low branches.
And I could do the wide open spaces with it attached and then take it off for the closer work, if the number of hours mowing with just a 60 was too much.
this grass is called centipede grass and I don't think it grows as fast as what I'm used to so my visions of worrying about twice weekly mowings might just be unfounded.
DR Trimmer has a new pull behind string trimmer made for fence posts I'm going to check out. My guess is one has to go back and do a light touch up afterwards.
I'm going to plant climbing roses on some of my white plastic fencing so I'll have to be careful not to chop those things up. These new HD trimmers come with some pretty radical tough line now; maybe too radical for plastic coated fence posts. topic for another thread.
   / 6 foot lawnmower needed #53
daugen, that DR pull-behind fence trimmer looks really slick. I wish someone would buy one and report back on whether they work good or not.
   / 6 foot lawnmower needed #54
I would be very interested in your final choices. You have made many.
I also have a lot of other equipment I'm trying to get optimal use out of; so while a new mower is nice, and does replace the one I gave away,
it's also another piece of equipment to maintain, to make space for. I have "collected" a few more things than I really need, but enjoy using them...
well the nice part of this forum is that you can sort of talk out loud and get feedback. for context, I grew up mowing 7 acres on our family farm, including an orchard and grape arbor. 35 more in field, 75 in woods.
mowed from Friday afternoon after school at 4pm til dark, ten hours on Saturday and two or three to finish trimming on Sunday afternoon. for my allowance of 5 bucks.
Two older brothers, they got the riding mower/s. I walked, I trimmed, raked gravel on a 1/4 mile long lane, emptied the incinerator, the lowliest of all unwanted jobs.
Pushed a hand mower for so many years, wore off many sets of wheels. Cub Cadet and Bolens garden tractors mostly, whatever the only place in town sold.
so now it's my time for a hopefully comfortable ride, and I need to remember I'm retired so a few more minutes on the mower are unlikely to be a burden.
A few more hours yes, which is what started my search for info in the first place.
I use the dealer more for service now than I did before, so buying what they service locally is important for me.
the least expensive DR pull behind line trimmer has been ordered. My local guy here sells a lot of their stuff.
   / 6 foot lawnmower needed #56
daugen, we will be looking for a report/review on that DR line trimmer once you get it and have a chance to use it. I've got over a mile of fences to mow on my 30 acres, and that one is on my radar.
I'll give you the straight scoop Poop...:D
CAT Skid Steer (A50322)
CAT Skid Steer...
2018 TAKEUCHI TL8 SKID STEER (A51246)
2018 TAKEUCHI TL8...
2013 HINO CONV. ICE CREAM TRUCK (A52472)
2013 HINO CONV...
2012 KINZE FLAT FOLD ROW MARKERS SET FOR 12 ROW 36/38 STACK FOLD TOOL BAR (A52748)
2012 KINZE FLAT...
Wright Sentar (A50120)
