Tiller 6 ft. Tiller Too Much for Ford 3000 Tractor?
   / 6 ft. Tiller Too Much for Ford 3000 Tractor? #1
browndd1
I have a 1967 Ford 3000 gas tractor that is 40 hp and I think 38 hp at the pto. Can anyone tell me if this tractor will handle a 6 foot King Kutter Tiller?
   / 6 ft. Tiller Too Much for Ford 3000 Tractor? #2
38 pto hp is plenty for that size tiller
   / 6 ft. Tiller Too Much for Ford 3000 Tractor? #3
That should be a perfect match for your tractor! Have fun with it. :p
Troy
   / 6 ft. Tiller Too Much for Ford 3000 Tractor? #4
HP-wise, you're covered......More than enough in fact. Problem MIGHT arise with gearing though. Is your 3000 a 6-speed or 8-speed. Low gear MIGHT not be low enough in some conditions either way, with 6-speed being worse of the pair. The only time it will be an issue is in sod or really hard ground.
It's an 8 speed
   / 6 ft. Tiller Too Much for Ford 3000 Tractor? #6
I have a 1968 Ford 3000 and use a 6' King Kutter tiller with it. It works great. Mine is an 8 speed too. I make two passes--three if I'm breaking new ground and it tills up beautifully.
2015 DODGE RAM...
TUBELINE TL50LSV LOT NUMBER 119 (A53084)
TUBELINE TL50LSV...
New/Unused CFG Industrial MX15 RX Mini Excavator (A51573)
New/Unused CFG...
HARDEE RD72M LOT NUMBER 154 (A53084)
HARDEE RD72M LOT...
2000 Kenworth W900 - 3406E CAT Engine - 78,980 Miles (A53472)
2000 Kenworth W900...
2010 International 4300 2,000 Gallon Water Truck (A52377)
2010 International...
