6 Ply ag tires verses 8 Ply ag tires ?
   / 6 Ply ag tires verses 8 Ply ag tires ? #31
Bridgestone Commercial Truck Tires <------ Please Read this article!
:confused2:Buncha simple double talk as near as I can tell. If they know what theyre talking about they need to introduce appropriate technical detail so as not to leave so many "hanging chads". It doesnt hang together all by itself.
larry
   / 6 Ply ag tires verses 8 Ply ag tires ? #32
larry
What are you talking about? Im confused..:confused:
   / 6 Ply ag tires verses 8 Ply ag tires ? #34
Not so true!! You can run radials down to 8 PSI. Which is why I will not ever run bias ply!!
See Michelin IF's for example.
What? You cant run them at 0 PSI? I mean, if air doesnt support the load, and the tire does, then run them at 0.
Obviously there are tough side walls that will hold some shape, but you do require air still...
   / 6 Ply ag tires verses 8 Ply ag tires ? #35
Right after you demonstrate supporting a load with air only; no tire.
Your word games are pointless and detract from the original discussion.
Time for us to simply ignore you. Good bye.
   / 6 Ply ag tires verses 8 Ply ag tires ? #36
For start - what is their baseline PSI? They say never inflate over the sidewall marked pressure.
377811 (A48836)
377811 (A48836)
UNUSED Single Stall Portable Toilet (A53117)
UNUSED Single...
Alliance Flotation Tire (A50123)
Alliance Flotation...
BW RVB3405 20,000lbs 5th Wheel Hitch Base (A50322)
BW RVB3405...
2025 IR IRMC 8D UNUSED Massage Chair (A53117)
2025 IR IRMC 8D...
2018 Toro Workman GTX Electric Utility Cart (A51691)
2018 Toro Workman...
