Sprayer 60 Gal. 3 Pt. Sprayer and Pump Problem
   / 60 Gal. 3 Pt. Sprayer and Pump Problem
Well, I gotta say I finally made it by TSC to talk about this bad coupler and they swapped it out without any paperwork (on my part) whatsoever. They agreed it did look like a bad casting. Very pleased with how I was treated by the folks at the Woodland California store.
   / 60 Gal. 3 Pt. Sprayer and Pump Problem #12
Kossetx,
Go checkout the Teejet website and look at all of their spray tips (which will work on this Fimco sprayer from TSC). You will see that they have a range of spray tips with varying spray rates that also vary based on PSI. Your tractor speed will also effect the application rate.
Most pesticides have a recommended amount of solution and a recommended amount of pesticide to be applied. For example, you may set up your sprayer (by choosing a specific spray tip, adjusting the PSI and choosing a particular ground speed) to spray 30 gallons per acer of solution and that solution would contain 2 oz of Glyphosate. So you are applying 2 oz of Glyphosate per acre caried by 30 gallons per acre of solution.
All of this will vary, of course, based on the label.
So to answer the question you asked, you set up the sprayer to spray the amount per acre that you want it to spray based on what the label says to do.
   / 60 Gal. 3 Pt. Sprayer and Pump Problem #13
My neighbor busted one of mine just like that by having the arm connected to the top link....when he raised the tank a bit too much, it sheared off.
You will get real tired of refilling if spraying a 40 AC field with a 55 gal sprayer. Get a 150 or 200 if you can handle it and you sure won't regret it. Also, I ran a 1 1/4'' hose off one of my wells just for filling the sprayers. It sure beats a garden hose.
   / 60 Gal. 3 Pt. Sprayer and Pump Problem #14
It took nine full tanks to do about 27 acres with my 60 gallon.
ksmmoto
Caterpillar 572E Tracked Pipe Layer (A55851)
Caterpillar 572E...
PALLET OF NYLON SLINGS, METAL TOOLBOX W/ CHAINS (A54757)
PALLET OF NYLON...
Oil Well Pump Jack with Motor (A52377)
Oil Well Pump Jack...
Tiger Mower Flail Arms (A55851)
Tiger Mower Flail...
2020 DRAGON ESP...
2017 Ford F-150 Pickup Truck (A55852)
2017 Ford F-150...
