I run a 60" Farm King blower on my
BX2350. Here are my observations:
- You can lug the engine if you load it too hard. Our most recent snowfall was just over a foot of very wet snow and if I went into at much more than a casual walking pace the engine would lug.
- With a normal snowfall of 6", I can run it full speed in reverse (low range) and the RPMs will drop by about 200 (in the snow versus not in the snow).
- I normally run the engine at around 3,000 rpm which is the rated PTO speed. I do this mainly to throw the snow as far as possible.
- Even with the extra width the front tires still run over the unblown snow on occasion. I'd hate to see what a 50" would be like in this regard.
- The 3PH has no problems lifting the blower. I do keep the FEL full of sand to throw on the hill in the driveway. The extra front weight definitely helps with steering and traction when backing up the hill while blowing. The tractor also has chains all around.
- The only time the blower comes out is when the snow is too deep or wet for the ATV plow.
- With all this being said, I'd definitely go with a 60" again.
