boggen
Elite Member
- Joined
- Feb 22, 2011
- Messages
- 3,789
- Location
- Trivoli, IL
- Tractor
- SSTT (Sideways Snake Tain Tractor) and STB (sideways train box) tractor, dirt harvester
I clicked the link, but couldn't find the manual for the RM59. I think this is the mower I have, it has been repainted. I am trying to find the belt part number so I can hunt another one down, and I need another tail wheel. Thanks
when ya click the link. it took me a couple minutes to see it, "finishing mowers"
top row, second from left side.
best suggestion is to take the belt off, and take to a local tractor part store. so they can measure things. if they have to order a belt, make sure you take old belt with you.
if you have ability. go ahead and take belt off, but also just load up the finishing mower and take with you. granted "flingers" near me. those folks know there stuff. but if it has been repainted. hopefully you will get a old timer that been there for years that is also a parts guy. and be able to look things over to find a belt for ya.
there are cheap belts and then normally more expensive belts. normally the more expensive belts can withstand a higher running temperature, and do not stretch at the higher temps and in that last much longer.
there should be a belt tension-er some place on the mower deck, see if it is in operating order as well. and if it will add or remove any amount to over all belt length, when belt tension-er is fully positioned one way or the other way.
