60' x 100' Pole Barn Build / Questions
   / 60' x 100' Pole Barn Build / Questions #11
GG...have you bought much lumber lately? It's at an all time high around here. I cringe when I have to grab something from the store....most of the time I cut a tree down and roll my own on the sawmill.
   / 60' x 100' Pole Barn Build / Questions #12
You can clear span 60' with an engineered wood truss. Lumber is very high right now. A clear span steel building may require additional concrete footings where the main beams will be setting ... I know of one that had "per code" needed 4'x5'x18" footer with rebar both ways. And then the 6" slab poured over them.
   / 60' x 100' Pole Barn Build / Questions #13
All this talk about codes makes me wonder why I have never checked those.:ashamed: I always check with an electrician friend of mine to make sure I do that correctly. I have never gotten a permit or checked codes for a barn or any other outbuilding. I should probably check on that next time.:D
   / 60' x 100' Pole Barn Build / Questions #14
Very odd, here in North Idaho wood prices are lower than they have been for years..maybe for as long as i can remember. No one is logging here cause you cant make enough $$ to pay for the loggers. They are cutting the crap trees fopr pellets is all i see.
   / 60' x 100' Pole Barn Build / Questions #15
I did a 30 x 50 shop and went with steel mainly for a maintenance issue. I didn't want to paint, didn't want to worry about insects, or fire and I'm getting on in years. I had a 4" slab poured on grade with 20" footers. According to the concrete contractor it would hold > 10,000lb load without problems. Cost for material minus concrete was under $15k.
Good luck.
Thanks for all the info!
I am leaning to a steel building but will keep everyone updated once we get going. I will also post the plans next week when I get done with them.
iDrive TDS-2010H ProJack M2 Electric Trailer Dolly (A55851)
iDrive TDS-2010H...
2012 MACK GU (GRANITE) CAB & CHASSIS (A56129)
2012 MACK GU...
CATERPILLAR 627K SCRAPER (A52707)
CATERPILLAR 627K...
John Deere 1025R Sub-Compact Tractor Mower (A56857)
John Deere 1025R...
2014 Ford Fusion SE Hatchback (A55853)
2014 Ford Fusion...
2002 Isuzu NPR-HD Box Truck (A56858)
2002 Isuzu NPR-HD...
