6010 vs 6011
/ 6010 vs 6011 #1
bdog
Elite Member
Texas
John Deere 6130M
I know 6010 (5P / 5p+) is a DC only rod and 6011 is AC or DC. I only weld with DC but have used 6011's for as long as I can remember. Other than the occasional times when I cap something with a 7018 I don't think I have used anything but a 6011 since I was in high school ag class nearly 20 yrs ago. Anyway was curious about the 6010 and just wondering what the difference is and if there was any reason to use it instead of a 6011 for general purpose welding? I have always heard it was a pipeliners rod but what does that mean really?
/ 6010 vs 6011 #2
Red rod, 5P, is closer to being like the 6011 you're used to welding with. I know the 6010 offers some welding characteristics that are important to critical welding processes over 6011. But if you're welding with 6011 and grab some 5P your arc and welding will change little.
I've found the 5P+ to be a whole different animal. Now all I've used the 5P+ with is with either a Miller Legend or a Miller Trailblazer gas drives. So the better arc you get with these machines might be making a difference not found in other machines.
For me the + rod's arc is more plastic and less harsh than that of P or 6011. I vertical ups on fourteen gauge all the time and I think a lot of that comes from the sweet puddle that for me is well, more plastic, is the only way I can express it.
After the weld though is where the 5P+ shines like new shoes though. That's because the flux cleans up a kazillion times easier than the flux on P or 6011.
On ask andy (Miller welding forums) this topic came up the other day and some guys are big fans of ESAB's 10P+. They say it's ESAB's version of 5P+ and it costs a lot less. I"m setting pretty good on rod right now but I plan to try the 10P+ the next time I buy. Mostly because one of the guys showed a pic of a pipe weld with it and I found it looked a lot like what I get with the 5P+, better of course because he's a real weldor.
/ 6010 vs 6011 #3
I always used dc machines,when I was learning and after and we always mainly used 6010..maybe never used a 6011? if I have not many for sure,but believe they are much alike,except the 6011 has a little different stuff in coating so's you can use it on ac.Maybe somebody who has run both lately can speak.
Pipeliner rod doesn't have same meaning it used to and even than it was used[6010,7010 etc] many other places than pipeline,,thing about 6010 verses 7018[the two main rods you might say],is one you can put a root in with and run downhill,the other[7018] roots are generally not run with them and they don't work to well down hill[top to bottom],rare to see any major construction using an ac welder with stick,,power plant type work is about all uphill,pipeline work is mainly downhill.
I use 5p +,6010,prefer it to the red 6010,seems smoother running.
Forgot to add,,you would need to run them both on dcep,than you could tell the differences.
/ 6010 vs 6011
Thanks for the replies. I have a trailblazer so maybe I can get some luck with the 5p+. Actually I will probably try the 10p+ since I saw those on the shelf at the local welding shop. I don't think they carry any Lincoln stuff.
/ 6010 vs 6011 #5
Is this what you're talking about Harv?;):D
Here is what the slag looks like on 10P-Plus.
/ 6010 vs 6011 #6
One of the shops I work with says that 6010 is a bit more pliable / malleable than the others. Not sure how scientific their tests or conclusions are but where they base that on is that they have a REALLY large roller in their shop so tend to roll up big pipes. I think the last thing they did for me was about a 72" diameter tank out of 1/8" I think it was.
They get the flat blank rolled into almost a circle (your last 12" or so come out flat) and they get it rolled till it is joined. Then they do some substantial tacks with 6010 and grind it flat then continue rolling it round, takes the two flats and rolls them into a smooth ring.
They said other rods they tried to do it with would crack and break as they tried to roll it through the roller.
Like I said nothing scientific.
Personally I get 50 pound boxes of 6011 and that is just what I use. My type of work involves more "close enough" than I would care to admit :)
/ 6010 vs 6011 #7
One of my Lincoln books has Fleetweld 35, (6011) with an as welded yield of 50,000 to 72,000.
Fleetweld 5P, (6010) yield is 50,000 to 65,000
Fleetweld 5P+, (6010) yield is 50,000 to 75,000
/ 6010 vs 6011 #8
From what I read the best all around rod is 6011 because you can use it in any welder and it will dig through rust and paint and has deep penetration.
6010 supposed to have the same characteristics but it is DC only and supposed to run smoother and easier to maintain arc. That said I never tried 6010 because I bought about 15lbs 6011, 5lbs of 7014, 5lbs of 6013 and 15 lbs of 7018 rods at a yard sale and they work fine for my need. It was interesting to learn how they run different but it means little in my welding. When this supply runs out I might buy some 6010 but that will be a year or three before that happens. They hold steel very well and that is my only need.
Edit: Nice root pass there Shield Arc. That must be a drag to keep the rod in the proper position on that small diameter pipe.
EDIT #2 I stand corrected by the below post. Thanks.
/ 6010 vs 6011 #9
Easy Go,
6010 is not easier to maintain/start an arc or smoother than 6011. It is harsher, more driving and more difficult to keep running stable. 6011 has arc stabilizers in the flux, but that reduces the penetration that it has compared to the 6010. The 6010 is favored because: 1) The penetration is superior 2) It is the fastest freezing rod that is commonly available and works well in out of position or in open root situations. 3) Welding speed can be quite fast in the forward direction. 4) The whipping action used to weld 6010 makes a small, narrow root pass, perfect for laying a fill or cap pass on top with a 7018. 5) Less flux.
I am sure there are more reasons, that Shield Arc or Gauthier can add, but these pop in on the top of my head.
/ 6010 vs 6011
Easy Go,
So in a nutshell if I have the ability / skill to weld with the 6010, and a DC machine, it would be a superior rod to the 6011 for most applications.
/ 6010 vs 6011 #11
Here is the inside of a 2-inch open root pipe welded with 3/32-inch 10P, (6010).
Here are some open root pipe test coupons I did with Hobart's 335A 6011. I don't run much 6011, but I really like this Hobart rod.
/ 6010 vs 6011 #13
one rod is sodium cellulose flux, and the other is sodium potassium, or something like that (it's been a while)
i find that 6010 is actually easier to run because it burns cleaner, the likelihood of slag inclusion is lower. that's why it is a better rod to run downhill.
in sawmills there is a lot of chuting, underneath equipment, that is designed to direct/contain waste wood/chips etc into conveyors. this is generally welded using 6011, even though it doesn't run quite as clean downhill, because it is more ductile than 6010 and better suited for vibration/shock loading.
/ 6010 vs 6011 #14
Gonna jump in here and expose my ignorance.
I have an older AC/DC arc welder that I use for repairs and modifictions of impliments. Lately I've been welding up sopports and fixing cracks on my rotary cutter.
For some reason that I can't explain, I've been using 6013 for everything that I do.
Would I be better off with 6010, 6011 or the 6013?
Thank you,
Edide
/ 6010 vs 6011 #16
i would agree that, if you only have a/c weld current, 6013 would probably be the best.
if you have d/c current, and can reasonably clean the area to be welded, then 7018 is probably the best answer. it is more durable than any of the other mentioned rods.
unfortunately, 7018 is a slower running rod that imparts more heat into the parent metal, and it requires a fairly high skill level (and a lot of heat) to run downhill... this leads to problems welding relatively thin metals.
depending on how thin the metal is, you may be able to take a 3/32 7018 rod and smack it against something solid and break the flux off, then place it along the crack in the same way you would lay a rod to tig or gas weld or braze. you then weave another 7018 3/32 with the flux on it, running between 80-100 dc amps, over top. this technique basically substitutes the burning 7018 rod for the gas or tig torch. as well it results in a larger weld deposit with a lower heat input than would normally be possible using this rod.
it may sound kind of tricky but once you get used to it, it's really a very handy solution to a wide range of problems.
it's really hard to beat the ductility of 7018, and when you pile it on large and wide you can really strengthen an otherwise weak area.
i'm not saying that it won't just crack next to the repair weld at some point, but if it does you can just pile on another layer next to the one that's already there and eventually the whole area will be built up to a larger thickness and subsequent strength.:)
/ 6010 vs 6011 #17
Best thing for you to do eddy,is get you a few of each and try them,,you can use dc electrode positive with all three,even though some rods can be used on ac,dcep is the way to go as opposed to ac,if you have the choice.If one don't want to run as good on dc,than don't use that rod,use dcep if you can.
I only have 6010 5p +,,most anything you will be welding on they will do in my opinion,a better job than 7018,,better all round rod,,[plus you don't need to worry about a rod oven],on most steel,,only time a 7018 might be needed is if you was fabing something thicker,say 1/2 inch thick and up,,and even than most would run root and hot with 6010 and out with 7018,,reason is a 6010 is a deeper penatrating rod than 7018,,and if its an open root as opposed to a fillit,7018 don't work to well,,also 7018 won't work very good downhill either[on your vertical welds].
As far as ductility[which is more ductile] that ain't an issue.All the rods you mentioned will beat the steel you would be welding on.
/ 6010 vs 6011 #18
actually, i think that's highly unlikely. the odds are that the deck is more ductile than any of the rods mentioned, including 7018.
i realize it is a generalization, and there are always exceptions, but the lower the tensile strength, the more ductile a metal usually is (with the exception of metals that readily work harden like aluminum and copper). the deck is probably much lower tensile strength than any of the rods.
far as needing a rod oven for 7018, that really isn't the case. i have gone on many jobs where the contractor left the rods from the last job in the c-can over the winter and trotted them out for us to use as-is. the structural steel on many industrial facilities have been welding using rods that were 'crusty' to say the least.
the main thing with 7018 for home use is to keep it at or above the ambient room temperature in order to avoid a situation where the rods are cold enough to draw condensation out of the air. basically, just keep them in the house somewhere that stays warm and dry and you should be fine.
i have always been taught to avoid ac weld current unless it is a last resort, so my experience with 6013 is limited, but i assume it is a more ductile rod than 6010 or 6011.
the main difference between 6010 and 7018 is that when you weld over a crack on thin metal, when the crack re-emerges with 6010, it will probably split along the centerline of the weld, assuming the weld runs along the centerline of the crack. 7018 will crack along the edge of the weld.
using the trick of breaking the flux off a 7018 rod and using it for a filler rod also works with any of the other mentioned rods as well.
the problem most guys have is that they don't understand the metallurgy behind the problems that they are trying to solve. there is a triangle that signifies the relationship between properties of metals. again, it has been many years, but i think the corners are labelled hardness, ductility, and strength (tensile). any metal can be placed somewhere within that triangle, the point being that if you move closer to one corner, you move further away from the other two.:)
/ 6010 vs 6011 #19
That may be true,the deck is more ductile than 6010 or 7018,bet it is,,but what does that mean really? who cares if the mower deck is more ductile than weld in this case? And I'll bet both 7018 and 6010 are about the same as far as ductility,,,,,remember,you are the one who brought up ductility,not me,saying 7018 was more ductile than 6010,,sounds like you are making my case for me,,,which is,,for your average backyard welder using a stick machine,a 6010,a 7018 a 6011 a 6013 weld will be stronger than the base metal if made correctly,,Ductility,,who cares in this case.?
I can think of many reasons I don't want to use a 7018 rod,[as opposed to a 6010 ],,ductility ain't one of them.
/ 6010 vs 6011 #20
what i'm getting at is that you have to try to identify the properties of the parent metal before you can make an intelligent choice with regard to selection of electrode or weld process.
that's a poor bet. there's a reason you don't use 6010 for tacking. (at least structural steel) and if you use 6010 root tacks on a pipe joint, most codes require that you complete the root (6010) and hot pass (7018) before you take a break or allow it to cool.
i'm not sure i understand exactly what you mean. basically, i always reach for 7018 first (if i have a stick machine handy- i'm usually working outside), if circumstances dictate that something else has to be done then i'll go with that.
6010 and 6011 are also very handy where you can't get all the grease/rust etc off the weld zone. often times it is better to burn a 6010 first, just to clean off the debris.
the bottom line is that eddie can probably goop that mower deck together with just about anything but, for me at least, it's always nicer to sort of understand what you are doing rather than guessing blindly and hoping for the best.:thumbsup:
