Sep 26, 2012 / 6180 puking coolant out the overflow #1 D DIESAHL New member Joined Sep 26, 2012 Messages 1 Location shippensburg PA Tractor Massey 6180, and a 5520 john deere have a 6180 that when we run it it will puke out coolant. changed the t-stats and still does it.
Sep 26, 2012 / 6180 puking coolant out the overflow #2 BobRip Elite Member Joined Sep 8, 2004 Messages 4,676 Location Powhatan Va. Tractor 2000 Power Trac 422 Try replacing the radiator cap and clean out the radiator air passages.
Sep 27, 2012 / 6180 puking coolant out the overflow #3 Wacky Veteran Member Joined Apr 4, 2010 Messages 1,107 Location West Virginia Tractor 2010 GC2610 If you have access to a pressure tester I would try that.
Sep 27, 2012 / 6180 puking coolant out the overflow #4 The kid Elite Member Joined Apr 25, 2012 Messages 4,113 Location Middle Tennessee Tractor 1965 135 gasser, 1967 135 diesel Check your manual to see what lbs radiator cap it should have. It may require more backpressure on the cap. On my 135 it's 7 lbs.
Sep 28, 2012 / 6180 puking coolant out the overflow #5 E Ed of all trades Elite Member Joined Jun 21, 2012 Messages 4,415 Location Waynesboro Va Tractor John Deere X310, JD LA 145 I agree with Wacky, pressure test, it could find problems that you can't see from the outside of the motor.
Jan 25, 2015 / 6180 puking coolant out the overflow #6 B buzzard3 New member Joined Jan 24, 2015 Messages 8 Location Dakota Tractor jd 4020 Hi, How do you like your 6180? Am looking to purchase a 96' model. Any pros and cons on the tractor? thanks
Jan 27, 2015 / 6180 puking coolant out the overflow #7 irvingj Elite Member Joined Feb 3, 2008 Messages 3,564 Location Etna, NH Tractor 2007 MF GC2310 TLB Going back to the OP (and 2+ years), was that problem by any chance a blown head gasket? Just curious.
