62 Inch MMM Constantly Breaking Belts - New Pulleys?
/ 62 Inch MMM Constantly Breaking Belts - New Pulleys? #1
The Suburban Farmer
Northern Virginia
Deere 2320
I have a 62" mid-mount mower on my Deere 2320 has been bullet-proof for the last few years. However, the original belt FINALLY broke after 7 years. I replaced the belt with an OEM belt, but now it's breaking belts every ~2 hours. Specifically, the belts appear to be wearing on the bottom of the belt first, then shredding rather than a clean break. When the belt is new, the cut quality is excellent with no odd sounds or vibrations that I can detect.
So far, I've:
  • Removed and cleaned the deck and checked for debris
  • Removed and balanced the blades
  • Checked for overall deck level
  • Checked the spindles and bearings (they seem to spin freely with no wobble or grinding)
  • Checked all the pulleys for burrs or knicks
  • Measured the pulley height against the main drive pulley to ensure they are all consistent.
I have to admit - I'm now stumped. After all the above, it looks like a brand-new deck - but it's still shredding belts.
I'm thinking of taking off all the pulleys and turning them on my lathe to see if they are out-of-round and maybe trying to refile the edges of the pulleys with a fine file in case there are any burrs I may have missed. Does that seem like overkill, or am I missing something simple that I should try before turning the pulleys on the lathe?
I've busted $250 worth of belts in the last couple of months and this is getting expensive! Any thoughts or recommendations would be greatly appreciated.
/ 62 Inch MMM Constantly Breaking Belts - New Pulleys? #2
Any indications on one of the pullies of excess wear? How is the idler? Perpendicular to deck, or angled so the bottom of belt is being driven towards deck? Spring tension on idler ok (no slippage when you hold blade & try to move belt)? How about the main gear box alignment? I had a sears mower deck where the casting ears would crack on the spindles & it was enough to tilt the pullies when under load, but seemed ok on a casual glance over. same belt shredding after heat & burnt rubber smell. Grease nipples or sealed bearings?
/ 62 Inch MMM Constantly Breaking Belts - New Pulleys? #3
Final thought ... any marks on the shrouding that belt(s) are coming in contact with the metal belt covers?
/ 62 Inch MMM Constantly Breaking Belts - New Pulleys? #4
If you see wear on an edge, either one of the pulleys is out of line or there is something sticking up on the deck rubbing the belt. Since this is a shaft drive deck, all the pulleys should be in exact alignment. I broke my first belt after about 5 years but I think it was because I let too much junk build up under the deck drive over ramps. The second belt looks fine after over 7 years. Other than taking the ramps and shields off and very carefully checking the alignment and clearances, I can't come up with any other ideas. If you can't find anything, I would go ahead and talk to the dealer.
/ 62 Inch MMM Constantly Breaking Belts - New Pulleys? #5
If like my X540 deck there are two or three hold down clamps that bolt over the belt. If one of these is slightly out of position the belt will rub. Also one or two guides that bolt on idler that can be installed incorrectly and rub on the belt.
/ 62 Inch MMM Constantly Breaking Belts - New Pulleys? #6
Probably not the issue here. The 62 deck, being a shaft drive, has no guides or retainers. The belt runs exactly in a single plane held on by single spring loaded tensioner.
/ 62 Inch MMM Constantly Breaking Belts - New Pulleys? #7
Little some thing for you to read:
I prefer the belt to be inside the pulley just barely not sticking out
and I lost too many belts the did not fit inside the groves
willy
/ 62 Inch MMM Constantly Breaking Belts - New Pulleys? #8
Change all your pulleys
Thanks again for all the suggestions. Just to close the loop here, it ended up being caused by a crack in the deck underneath the pulley tension bar. When I took the tension spring / swing arm assembly off the deck, I saw that the deck was cracked underneath. As a result, the deck was structurally flexible enough so that the spring tension would pull the entire assembly out of square when under tension. Not sure how it cracked since nothing else was damaged and I don't recall hitting anything, but some welding and grinding and all is now good. I was surprised at how badly it was cracked. You can also see where the idler pulley rubbed off the paint as a result of being pulled out of alignment.
Hard to see in the pic, but I tried to put arrows where the major cracks were. I used a Dremel with a diamond tip to open up the cracks, and then welded from both sides. As extra insurance, I also put a large washer on both sides of the deck to help spread the load a bit. Seems to be working good-as-new now.
/ 62 Inch MMM Constantly Breaking Belts - New Pulleys? #10
Cracking of this sort is usually caused by fatigue and not by hitting something..... If its cracking the structural design is to weak to maintain the forces needed to keep tensioner operating properly....
/ 62 Inch MMM Constantly Breaking Belts - New Pulleys? #11
Wow. Given how heavy the deck is I almost wonder if there was a manufacturing error that cracked the deck when they punched the hole. You should certainly be good now.
/ 62 Inch MMM Constantly Breaking Belts - New Pulleys? #12
When you put washers on both sides of a plate, use different size on each side to prevent the shearing action around the washer.
/ 62 Inch MMM Constantly Breaking Belts - New Pulleys? #13
You found a plausible cause and effected a working (for now) solution. mini14 suggested the solution to another possible cause--worn out sheaves. I have a 30 year old JD F510 front mower. The oem belts are kevlar "A" belts and expensive from JD. When the deck belts began to fail frequently, I measured the sheave width at the outside, thought "B" belts would be a better (and cheaper) fit, and have had reasonable success. This past season the primary (oem) belts began failing in less than 2 hours--twisted and shredded like you described. After an experienced tech rep told me the sheaves were worn out I examined mine. V-belt sheaves should have a pronounced, straight sided "V" shaped profile; mine had a "C" shaped profile that allowed the loose "A" belt to rotate (twist) and self-destruct. "B" belts work because the extra width can ride on the flanges, but the real solution will be new sheaves.
/ 62 Inch MMM Constantly Breaking Belts - New Pulleys? #14
How is the idler? Perpendicular to Speed Test deck, or angled so the bottom of belt is being driven towards deck? Spring tension on idler ok (no slippage when you hold blade & try to move belt)? How about the main gear box alignment?
UNUSED FUTURE 32" HYD TILTING BUCKET (A52706)
UNUSED FUTURE 32"...
2005 Peterbilt 357 Truck (A55973)
2005 Peterbilt 357...
2009 Honda Odyssey Van (A55758)
2009 Honda Odyssey...
2014 Ford Escape Titanium SUV (A59231)
2014 Ford Escape...
2017 Wacker Neuson LTV6 Towable Light Tower (A56857)
2017 Wacker Neuson...
2015 MACK GU713 DUMP TRUCK (A59823)
2015 MACK GU713...
