gerard
Veteran Member
Iron Horse said:My WIA 240 volt AC 160amp (output) stick welder is 15 amp input . I burnt out a new 5500watt generator trying to weld 1.5mm shed purlins together . I had to buy a new 8000watt generator to run it . I have since bought a 12000watt generator which powers it just right . Buy the time ive finished a 3.2mm rod it is (the rod) starting to glow red hot and the penetration is very good . The caracteristics must all be different with our 240 volt Ac compared with your 110? volt Ac .
We have 110 AND 240 volt in most residences. Small migs can run on 110, larger ones need 240. I don't know of ANY that will do much with a 15 amp, 110 volt input. You could weld really light stuff without tripping the breaker but most 110 migs get put on a 20 amp circuit. My stick welder, which runs off 240 volt is on a 50 amp circuit (50 amp input needed for the MAX output capacity. This is the same capacity as an electric stove. Now I've never welded anything at max capacity becuase I haven't had anything that thick or rod that heavy but that IS what the plug and circuit are rated for)
