6420 transmission issue
/ 6420 transmission issue #1
Lone82
After working the tractor for a while it takes about 100 feet to stop in forward after pressing the clutch or throwing it in neutral. Reverse stops but when u let of the clutch there is no smooth takeoff, just takes off like you popled the clutch. Forward is not as bad but still aint good. Sometimes when you back up and grow it in neutral it acts like its taking off forward like its in reverse and forward at the same time
/ 6420 transmission issue #2
Sounds like a hydraulic leak on a o-ring in the clutch pack.
2008 SHOP MADE (A68842)
2008 SHOP MADE...
7ft Fork Extensions (A66734)
7ft Fork...
CM TRAILER  10 FOOT ENCLOSED TRAILER (A67714)
CM TRAILER 10...
10' Sheets of Tin (A64912)
10' Sheets of Tin...
Engine knock
Engine knock
2019 Ford F-550 4x4 Altec AT40G 40ft. Insulated Bucket Truck (A64556)
2019 Ford F-550...
