PatrickS2222
- Joined
- Feb 6, 2016
- Messages
- 494
- Location
- Brisbane, Australia
- Tractor
- MF35, MF135, MF203 with loader.
Adding tape to the threads on these pipe nuts won't help seal - pressure on the tapered olive against the corresponding internal taper inboard of the threaded section the screw into is what seals the connection.
Are the female threads in as good condition as these?
After you have tightened the pipe nut, does the hose feel tight - is it difficult to twist?
Those crimp-style hose clamps might not be tight enough - try replacing them with regular hose clamps?
Maybe the pipe flare nuts just need tightening a LITTLE more? Be careful, especially if they screw into aluminium!
Another possibility is a crack in the pipes. Do BOTH ends leak?
Bottom line, read carefully The Pump Guy's post No7 and Banjo Dunn's post No8 - I'm unfamiliar with US-spec machines but I can't recall seeing any rubber seals on 35s, 135s etc.
