650G - Burning through plugs!
   / 650G - Burning through plugs! #31
Genesee Products - Electronic Ignition for Agricultural and Industrial Equipment ignition coil, Parts Accessories, Yard, Garden Outdoor Living items on eBay.com eBay Motors: 12V IGNITION COIL points-type w/internal resistor (item 180251876881 end time Jun-15-08 16:56:00 PDT). dont know napa part numbers.try links.i would guess it would be a ford courier type coil.DID YOU TRY THE PROPANE TORCH TRICK.it sounds like a good test.never tried it though.does the coil you have on the tractor have a internal resistor?http://www.partsamerica.com/product...AR&MfrPartNumber=1788025&PartType=190&PTSet=A
   / 650G - Burning through plugs! #32
Hey Brian or any one with info to this interesting condition, I was just wondering how this situation came out? Was there ever a resolution to this issue? If so what?
Boo
   / 650G - Burning through plugs! #33
Brian, almost any coil should work. It being a point, and condenser firing system. Coils going bad are known for running for 15-20 minutes then shutting down. This is due to the heat getting to then, expanding the internal winding, and causing parts, if not all of the winding to short. You should be able to run a 0.035" sparkplug gap. It's a gasoline engine, makes little difference what make. If you have compression, spark, fuel, timing correct. It should run, and run, and run....
   / 650G - Burning through plugs! #34
Four years later I'm reading this thread which has me sitting on the edge of my seat. Its got all the makings of a classic Mitsubishi-Satoh novel. Does anyone know if the issues were resolved?
We want to know.... "Who threw the pie?"
   / 650G - Burning through plugs! #35
i'm with you Lebby.... curiuos about the final outcome, duhdunh (sound effect)... did he torch it... or fix it
PALLET OF SCAFFOLDING PARTS (A52706)
PALLET OF...
2010 FORD F750 XL SUPER DUTY DUMP TRUCK (A51406)
2010 FORD F750 XL...
2017 Chevrolet Tahoe SUV (A52377)
2017 Chevrolet...
2020 FREIGHTLINER CASCADIA 126 TANDEM AXLE SLEEPER TRUCK (A52141)
2020 FREIGHTLINER...
2020 FREIGHTLINER DEBRIS BUCKET TRUCK (A51406)
