655a ford loader backhoe
/ 655a ford loader backhoe #1
Cisco1
reno,no
655a ford
oil in crankcase increases like some fuel is getting into crankcase . Not sure what is causing the increase
/ 655a ford loader backhoe #2
no direct help to you.
the ford 555c TLB shop / service manual i have. was worth the 150 to 200 bucks i paid for it. gives full break down of parts and how to tear stuff apart and put it back together, testing stuff as you go. along with diagrams for most part each step of the way.
Document Moved -> north amaerica -> english -> parts catalog (some place along top) = a online parts manual diagrams are just enough to identify parts for ford / newholland stuff and get part numbers for everything. it might help ya identify gaskets and like.
i would more likely suspect coolant (water / antifreeze) mix getting into the engine oil vs fuel. the only time fuel entires the engine is during the fuel injection portion of the engine. everything else for fuel sets on the outside of the engine.
I believe if water or antifreeze was entering the crankcase there would be foam in the crankcase but their is none. I suspect fuel as the fuel tank is located above the engine .
/ 655a ford loader backhoe #4
You have an inline injection pump with a primer (lift) pump mounted to it. The primer pump diaphram has a hole in it most likely.
Bobcat Pallet Forks (A64127)
Bobcat Pallet...
2021 Big Tex 14ET 18' Tandem Axle Trailer (A62679)
2021 Big Tex 14ET...
2016 WEILER P385A ASPHALT PAVER (A62129)
2016 WEILER P385A...
2019 FORD F-250 SUPER DUTY (A65643)
2019 FORD F-250...
2016 Peterbilt 579 Day Cab w Hydra Flow Setup (A62613)
2016 Peterbilt 579...
New/Unused Landhonor Quick Attach Pallet Forks (A65583)
New/Unused...
