6610 fuel feed pipe
/ 6610 fuel feed pipe #1
Wlcote
Ford 6610
Hi have a Ford 6610 issue engine stops due to no fuel tends to bleed with difficulty then starts
Only issue seems to be movement on the delivery pipe connection to the filter housing although nut is tight can i replace short length of pipe with connection or can the rubber oring be replace the short pipe connects to a small rubber hose to the tank
