7 ft tandem or offset harrow
   / 7 ft tandem or offset harrow #11
Be specific and educational.
At work now, so not a lot of time. But specifically, I was referring to things like leaving ditches or poor finish. Those things can be eliminated. I should also appologize for say "most", when I meant "some". Most of what you said is true. Sorry about that.
   / 7 ft tandem or offset harrow #12
I have that exact Howse disk. It has sealed roller bearing and the angle of the blades can be adjusted for the conditions.
All gangs have the scalloped discs on mine. It cuts very well.
   / 7 ft tandem or offset harrow #13
I have pulled this disc and a normal gang disc quite a bit. The off set disc pulls like a boat anchor, will go deep when needed and does leave a rougher finish than a gang disc. This one does leave a small dead furrow that can be covered on the next pass. It does not pull the tractor to one side or the other. 7' wide orchard disc out of California. Not sure how it ended up in Illinois. It needs a new home
Dan
Two Post Car Lift (A50120)
Two Post Car Lift...
2013 Ford F-550 Ext. Cab 4x4 Auto Crane 6406H 6,400LB Crane Service Truck (A53422)
2013 Ford F-550...
2005 Ford F-650 2,000 Gallon Water Truck (A53422)
2005 Ford F-650...
Giyi 44" Mini Grapple (A53316)
Giyi 44" Mini...
2016 Club Car Carryall 1500 4x4 Utility Cart (A55787)
2016 Club Car...
2015 FORD E350 16FT BOX TRUCK (A54607)
2015 FORD E350...
