7-way plugs....anything better out there
   / 7-way plugs....anything better out there #11
used the molded one for years on several trailers never had a problem. on one of the work trailers the owner just swapped on a hopkins metal one at the beginning of this year because like you he was having issues, well see how it works. i think it is a little too tight
   / 7-way plugs....anything better out there #12
I like the looks of the Pollak metal body connecters. I bookmarked them.
   / 7-way plugs....anything better out there #13
TSC usually carries the molded plugs attached to the cord.
so does northern tool.
   / 7-way plugs....anything better out there #14
These. http://ezconnector.com/
I've put them on my horse trailer, snowmobile trailer, and truck. Haven't switched the flatbed over yet, and that's the only one that still gives me connector problems. No more corrosion issues on the contacts. Cable is molded into the connector. Truck side is well made as well. I've also got both adapters, so I can haul a traditional 7pin trailer, or have my trailer hauled by a traditional 7pin truck.
   / 7-way plugs....anything better out there #15
I too have the ez connector and it is a fantastic improvment over blade connectors. The plug attaches to the tow vehicle with a magnet so if you forget to unplug or jacknife the gooseneck and stretch/yank on the cable just releases instead of ripping your wiring apart. Very well engineered. It is expensive compared to bladed connectors but if you figure in the agrivation and down time created by bladed connectors needing constant replacement it is a good investment. I operate my trailer commercially and will never go back to chinese made bladed connectors. If your looking for something better, this is it, hands down.
   / 7-way plugs....anything better out there #16
Remember anything you put on you will need a adapter to the 7 way plug. So that way if you ever need to tow another trailer you can
2020 Bobcat T595 (A57148)
2020 Bobcat T595...
2020 Husqvarna YTH22V46 46in Riding Mower (A56859)
2020 Husqvarna...
2022 Schulte SMR-800 Multi Rake Landscape Windrower (A56438)
2022 Schulte...
CASE IH MX220 MAGNUM TRACTOR (A58375)
CASE IH MX220...
2016 GMC YUKON SLE (A58375)
2016 GMC YUKON SLE...
2011 MULTIQUIP LIGHT PLANT/ FUEL TANK TRAILER (A58214)
2011 MULTIQUIP...
