7040 Questions
   / 7040 Questions #31
you are about to make a big investment here....having had the 7040 and now 8540 (12 sp) i can say that the difference between them is huge, not just in the HD transmission w/more gears....the 12 speed also has the higher capacity 3 pt lift. in addition, the transmission lock e brake (much safer! when on & off the tractor frequently), more pto power, hyd. brakes (nice!), longer wheel base for a smoother ride, and more guts in the fel w/the larger frame.....all in all, much more machine imho. do get the hyd shuttle . i would strongly look at the 8540 if u go w/Kubota. good luck
   / 7040 Questions #32
btw the 8540 has a slightly smaller tire size than the 9540, but the 8540 will accept the 9540 size. i have seen the larger tire size on the 85's before....since you're going w/the cab, you might inquire about the larger wheel size should u go w/the 8540...just be sure the ft & rear are matched accordingly either way
   / 7040 Questions
Thanks for the insight. This is getting very interesting. When I look at JD and Kubota, I basically have three tractors that get my attention. The Kubota M7040, M8540, and the JD 5083E Limited. The JD 5083E Limited has a little more HP and weight than the 7040. It also has the 12F/12R. It looks like the price will be close to the same between those two tractors. Then, the next step up is the M8540. I will spend about $5,000 more for that tractor. There is a lot to consider here.
Also, I have not ruled out the Massey's and New Holland's either.
I am hoping to take a look at a JD 5083E Limited today. The local dealer has received the ok from a customer who bought this tractor in May. I can go with the dealer to look at the tractor any time. Its just a matter of finding the time to get away from work.
   / 7040 Questions #34
If physical size is an issue then check out the measurements of the different tractors.
The M7040 fits in my barn just fine but the M8540 would only clear the opening by a few inches. That was not the only consideration, of course, but it is something worth thinking about beforehand rather than finding it out the hard way.
There are a lot of posts on TBN about tractor height causing garage door "issues".
   / 7040 Questions #35
We are proud owners of the M7040 HDC-1. We love it.
I am not familiar with the 8f/8r gears & or the creep speed info on this thread. We do have a lever that (in my non technical description) is kinda like a cruise option with a turtle and rabbit picture - used it once. LOL. I've been keeping it simple in 1st, 2nd and 3rd gear - never been to 4th yet. I will have to read the owners manual - I intended to read it soon enough anyways... just been busy. I am new - I don't know much - not yet atleast. :)
I was quoted $47,150 for the M7040 with a loader, cab, 4WD, and cast rear wheels. Any thoughts?
You can do MUCH better than that... I don't know if my price was a special one time thing or if it is offered to everybody - but I can tell you we did a lot of research and price comparison before we decided... your results may vary.
   / 7040 Questions
How much better can I do? PM me if you would rather go that route. Thanks for the help.
   / 7040 Questions
The Kubota specs state that both the 7040 and 8540 top of cab height is 101 inches. The JD 5083E Limited is 98.8 inches.
I have already measured my garage doors to make sure the tractor will fit in the bay where I want it to be. All of the models I have been looking at should fit. We should be good to go!
   / 7040 Questions #38
When I did a quickie quote off of Kubota's website, I got a retail/list price pretty much the same as your quote. I figured it was probably due to you having a lot more options on the tractor you got a quote for, but did not explain in your post.
You should go online and go through the quote process yourself. That way you can enter all of the options that are on the tractor you are looking at.
I read a lot of people get around 14% off of retail/list price. My experience was similar.
If your quote is close to list price, that is way too much.
   / 7040 Questions
When I build the identical tractor on Kubota's website, I get a price of $45,963. So, the dealer quote is only $2406 less than the website. That's only about 5% off of retail price. That's why I think this quote is pretty high. I am investigating some other options right now. We'll see.
2011 Nissan Rogue SUV (A53424)
2011 Nissan Rogue...
2019 HarbinGer V3 Plus 8KW S/A Towable Light Tower (A52377)
2019 HarbinGer V3...
2017 NISSAN NV200 VAN (A51406)
2017 NISSAN NV200...
LIKE NEW 2023 Rhino 84in Reverse Rotation Rotary Tiller (A55218)
LIKE NEW 2023...
2020 Isuzu NPR Heil 8RLDB 8CuYd Rear Loader Garbage Truck (A52377)
2020 Isuzu NPR...
2007 PETERBILT 379 TANDEM AXLE SLEEPER TRUCK (A54607)
2007 PETERBILT 379...
