72 inch MMM raise and lower
   / 72 inch MMM raise and lower #1
chicklin
Columbia, MO
None....yet
Just got my JD3320 with 72" mid-mount mower. Cuts great, the only thing I'm not sure about is that it barely moves when I operate the 3rd SCV. As in it might move a half an inch either direction. Is this normal? I was hoping to be able to pick it up quite a ways when not using it.
I haven't really had time to get under there and look at it yet as I just got it today, but I thought there might be a quick answer. Thanks.
   / 72 inch MMM raise and lower #2
I have a 4310 with the 72" MMM and I adjusted the turn buckles on the rear as high as I could and lowered the deck height adjust down and re-leveled the deck. I have about 6 inches under the deck, or about 3 inches under the deck wheels when all the way up. I take the deck off when I use the loader or box blade. The deck is too expensive to tear it up when doing other work that I really need the clearance for.
I'll give that a try, thanks. Haven't attempted removing the deck yet, either.
   / 72 inch MMM raise and lower #4
It is not hard to get off, but it is very heavy to move once off. When I clean mine it is all I can do to lift it up to clean it out.
2016 Ford Explorer AWD SUV (A55853)
2016 Ford Explorer...
2021 Club Car Carryall 500 Utility Cart (A55851)
2021 Club Car...
2019 Chevrolet Silverado 3500HD 4x4 Crew Cab 10FT Flatbed Truck (A51692)
2019 Chevrolet...
2025 SDLL30 Mini Stand-On Track Loader Skid Steer (A53421)
2025 SDLL30 Mini...
Galvanized Livestock Wire Gate - 4FT x 11.5FT (A55302)
Galvanized...
FAE UML/SSL 150 VT BL HYD MULCHING HEAD (A51406)
FAE UML/SSL 150 VT...
